Scott in Bellingham
    5
Everything posted by Scott in Bellingham
  1. new outlook on this project heres the new list Legacy EJ running gear 5 bolt LSD up front Welded rear diff EJ2.2 adapted to Dual/Range tranny Nissan divorced transfercase 31" Mudders I almost have all the details finished on the EJ lift so looks like Ill get back on this , wish my pictures were back
  2. the struts are the limiting factor on the tire size
  3. shifter may hit the body sheet metal , yes you will need to bash the inner fender well, yes paypal does that sometimes, not sure why, I sent you a email to fix that,
  4. you could use any EJ tranny and weld up the center diff wouldnt have as low a gear , the EA tranny is used cause it all bolts up
  5. the strut block should sit at a 12 degree angle , so on a 4" lift the hole difference from top to bottom should be 27/32 inch . set the block on the table and take a square to it and measure in and thats what the difference should be from top hole to bottom hole Scott
  6. thats what you need Jeff another project
  7. got a 88 EA82 Turbo starts and runs ok when cold but shut it off when warm and it wont start again, let it sit a bit go back and it starts right up, Im not sure what to check any clues??
  8. I'll get some pics , and yes for the crawl ratio, this things a tractor
  9. this things coming back to life, turbos coming out anyone need one ?and putting in a EA82 carbed, , back will be hacked off and with some fab tricks it will have avesome adjustable flex you will be amazed , stay tuned as I may move slow on this , Kenny were are you?? plans are to take it out when kenny takes his suba -sammy out
  10. your right I found one tonight , I think Ill put the EA82 with carb into the turbo car and sell the turbo, other then trying to get it to run right , then rework the rear section for massive flex:)
  11. so there is 3 different strut lengths ? or ???
  12. why? I have a turbo mpfi car with the wrong comp and wiring and I have a good EA82 SPFI engine
  13. I have EA82 SPFI , so if I get a carbed intake and a a carbed disty theres no computer??
  14. can this engine run without a computer , say with a carb and a ???? disty??
  15. theres a local guy here that has a set of struts off a' 98 Impreza Outback Sport , is this what I want to lift my legacy sedan?? are the springs lighter on that car ?? whats the options on these ? are there only 2 different ones or ??? thanks Scott
  16. Kenny
    I got them cut they are sitting on the bench if Im not there Scott
