whynot
whynot last won the day on October 20 2018
whynot had the most liked content!
Location
WA state
Vehicles
1999 Subaru Outback
Recent Profile Visitors
828 profile views
whynot's Achievements
USMB is life! (4/11)
16
on my 99 I changed the head gaskets, and the overflow system worked ok, even with a leaking water pump. I changed the water pump, and now the coolant does not return from the overflow tank. No bubbles in the overflow tank. Tried a coolant pressure tester, and could not get a good seal, so I hooked up about 10 psi of compressed air to it, for about 20 minutes looking all over, and can not find a leak, and not loosing coolant. I am going to get a new radiator cap. it was new before the head gaskets went bad, and the same one from before the water pump change. could the head gasket failure ruin my cap? it was shooing water out of the radiator. and if so why did it work with a leaking pump?
when the ring is compressed, and you push it into the cylinder, the compressor is pushed against the block, and the compressor and cylinder wall act as one cylinder then when the rings get into the cylinder they set against the wall of the cylinder, and the compressor falls off On other cars I have always ended up using the ratchet type, I could never hold the compression required and maneuver everything. This is one I use, https://www.oreillyauto.com/detail/b/lisle-4148/tools---equipment-16488/mechanics-tools-16816/engine-tools-17994/bb466241b099/lisle-ring-compressor/19500/4413526/1999/subaru/legacy?q=ring+compressor&pos=0
