whynot
Everything posted by whynot
fill those cans with sand. Liquid sloshes around and can be dangerous. Tube sand is 60 lbs and 5 bucks or so. so less than 30 bucks you can do sand, have a traction material, and if not needed, throw it in the side yard or spread it on the grass when you are done with the winter. Sometimes we try and reinvent something that already works pretty well.
So far so good I do not see any signs of head gasket issues in the 200 miles. Do have a heater issue, lots of heat in town, goes cold on the highway. Seems odd. Any ideas? Could it just be the hoses are backwards on the block? I do have a subaru t-stat. and radiator and overflow bottle are full and working normally. Thanks
I also think that the small passages in the radiator would increase back pressure and make your pump work harder. the hose would have no restriction in the flow. Also, less efficient, but you could use blue pump discharge hose (maybe they sell it in black?) and when you turn the pump off it could self drain, and not have to be removed in the winter... (king of lazy my wife might call me???)
I feel your pain, been there, like i said before, this is exactly what mine was doing after I changed the gaskets the 1st time. Sucks. But I put another 500 into it and so far it appears to have fixed it. My mistake was assuming that what was good enough prep work for other cars I had done, was good enough for this one. It was not, and also the Subaru gaskets.
cool thanks for the offer. I am going to see how it goes I found one off the help section for a gm. Have not tried it yet. I think I will try that on my next day off, and if not, then I will just wait and see if the head gasket replacement has fixed the car for good. them go find anther light, and possibly a bumper. make it look as good as we can for a 20 year old car.
almost identical to what i went through. Spent 4 months trying everything under the sun, hoping it was not the gaskets. it also would not run the overflow correctly. it would push into the overflow, but not pull from it. and kept building air in the cooling system over time. after overheating again, and blowing water out of the top of the radiator again, I did them again, and used GD's method for machining at home. hope you have better luck than i did..
I do not know who did the head gaskets, or what they used for pI did mine in april. used fel-pro gaskets, and made a few mistakes on surface prep, that were fine for the dodge and ford I have replaced head gaskets on before. I just finished doing them again, with Subaru gaskets and better prep. The subaru gaskets are much different. So maybe look into what was used, and what prep work they did? I just got mine back on the road, so we will see if that resolved the issues
I picked up a head light at the pick and pull, Got ready to put it in, and noticed that the mounting for the bulb is different. one has a screw on (one I got) and the other has a clip in mount (the one that was in the car). Looking at the new ones on line they are all screw in mounts. This is where the bulb mounts into the headlight. my car is a 99, not sure what to do now. do I go back and get the plug, and use the good light housing I found, or change both, or go find a light that has the same type of mount, and does anyone know what year to look at? Thanks
headgaskets were 80, at one 50 at the other. I think it is the dealer. and they always need my vin why? they are engine parts do they really need me to get the vin to get me a part, Sorry just frustrated thinking of all the parts i got from them and thinking that i hve been charged that much more on all of them, it adds up. well picked it up last night, got to get it on today and go for a drive...
so i found thee 2 plugs, the spade connector i found where it goes, the 2 pin one, i can not find a home for. i assume it is one of the two you mentioned. going to go look again,, also on the crossover near the other one? also, the alt. is not charging. does it go anywhere except to the battery? the bolted wire and the plug connection.
