I'm in luck then. Mine's not a turbo. I was able to get it to run for a duration after removing the air flow sensor, disassembling the sensor, and spraying carb cleaner through it, and across the filaments. It ran for less than 10 minutes, after which the sensor again had motor oil in it. I suspected a PCV valve was malfunctioning, so I've removed it, checked it, seems OK, not stuck... So I've reassembled it, and I'll wait til it's light out again in the morning to get back to it.
