Wiclipse95
Everything posted by Wiclipse95
Rain getting into my brat!
Wiclipse95 replied to 73mako's topic in Historic Subaru Forum: 50's thru 70's
Probably your window seal. Is it pudling up on the driver side floorboard? My first gen was leaking from the plastic window seal insert right above the steering wheel. -
2 Flying Saucer Hub Caps for Sale
Wiclipse95 posted a topic in Historic Subaru Forum: 50's thru 70's
I have 2 Flying Saucer hub caps for $$. Both in good condition for their age. Message me if your in the market! -
1978 subaru wagon 5 speed in Brat
Wiclipse95 replied to DPM's topic in Historic Subaru Forum: 50's thru 70's
Ironworkerboomer is right -
1978 Subaru DL potential ignition problem.
Wiclipse95 replied to penguu's topic in Historic Subaru Forum: 50's thru 70's
I was having the same issue with my 79, it was the float sticking on mine. Also I see your in Utah, I'm in Colorado and adjusting the Carb for the correct elivation is crucial. Good luck, keep us posted. First gens forever! -
3 rubber mats for 1979 wagon
Wiclipse95 replied to mrtoni's topic in Historic Subaru Forum: 50's thru 70's
Picks? -
I was having the same issue a few months ago, I replaced the fuel filter in the top left corner of the engine bay ($3). It did not fix the issue the first time arround so I disconnected the rubber hose from the front of gas tank and used a compressor to blow out the fuel line (towards the front of the car) and replaced the fuel filter again. There was a bunch of build up that blew out, (make sure you have the fuel filter under the hood detached and line free to purge). That did seem to fix the issue at first however a week later I was travleing to Avon (about 30 miles away) and my Brat flooded out while driving. She started back up roughly and hour later and I took her back home. Since then. Rebuilt and rejetted the carb and have had no issues. Just so you know there is no filter in the gas tank on the first gens. The fuel pump is a good place to start as well, when you turn the key to the on position you should here rapid clicking. Similar to the sound you here when typing on a iPad or smart phone. If your not hearing that noise you probably have a bad fuel pump or poor connections to the fuel pump. Good luck, keep us posted
Meet RubySu (1979 Subaru DL)
Wiclipse95 replied to Jmpjose's topic in Historic Subaru Forum: 50's thru 70's
It's my Brat's big brother, I have a 79 same color same brown plaid intirior. I have been looking all over the country for a new seat, I want to stay with the originals but my driver seat is toast. Let me know if your ever up I-70. I would love to see it in person! -
1979 Subaru Brat flooding while driving?
Wiclipse95 replied to Wiclipse95's topic in Historic Subaru Forum: 50's thru 70's
Thank you -
Its an exact replacement, is there any way to adjust it? -
Hello, I'm not sure what's going on with my Brat. I am by no means a carb expert, but I think I'm flooding. While driving my Brat stops responding to the gas pedal and idles down to a stall. I let the car cool down for an hour and it will fire right up again. This seems to happen when I drive 30miles or more. It has happened to me 4 times now. I believe I am running a lil rich, the make shift exhaust I'm running backfires when I let off the gas pedal while driving. The carburetor was just rebuilt, jetted and all has all new gaskets. I checked for cracks on all the hoses connecting to the carb already. I know carbs can be pretty finicky. Has anyone else had a similar problem?
78 Brat is on its way here...
Wiclipse95 replied to biffanyus's topic in Historic Subaru Forum: 50's thru 70's
Any Pics of your new toy? -
1979 Subaru crankshaft problem
Wow, I haven't seen anything quit that bad before. I'm suprised you weren't having more noticeable problems. There is a 1980 parts Brat in Fort Collins for $400. Parts cars are going to be your best bet with random ea71 parts. Which Subi do you have?- 4 replies
- Crankshaft
- EA-71
(and 2 more)
Tagged with:
Are you interested in selling the OEM Shift knob?
Impressive work, I really like the way it's turning out!
Wow, unbelievable thread, great work! The dash looks amazing. Where did you get the black carpet templet? Keep up the good work
here is a list of items I'm looking for: Gas tank Passanger side mirror Jump seats with Mount Jump seat seat belts Jump seat head rests Passanger side tail light Weber carburetor Driver side Brown upper intirior door panel OEM shift knob OEM 4x4 shift knob Front carpet Washer fluid spray nozzle (monted on hood) Brown Plaid Driver or passanger seat (just need 1) Spare tire mount screw (the bolt and washer that hold down the spare tire) Rear sliding window Let me know what you have, thanks for your time My cell number is 614 893 1457, it would make it easier to communicate back and forth and show picks
