Norazburu
Location
Flagstaff az
Referral
Need help
Biography
Heavy equipment tech. And subui owner
Vehicles
2010 subaru outback
Norazburu's Achievements
Member (2/11)
After having worked all day fixing john deere tractors I attempted to pull the engine on my wife's 2010 outback. Got it out, pulled heads...Wich looked pretty crummy and sent parts to machine shop. Here in lies my faults when pulling the engine the torque converter was dislodged enough to drain fluid. I'm sure this is different than a john deere back so what is the best way to get the torque converter back in...and how do I fill the transmission with what it lost, and what kind of fluid did I actualy loose. Thanks Chris
Well I think I just got my answer today. Put new OEM subaru thermostat and got burp funnel filled overflow to full line drove home , approx 20 miles and opened hood when I got home and saw the dreded bubbles in overflow, which also rose from previous level.....so yes a 2010 with the mls head gaskets can fail at 130,000 miles. Very dissapointed but still best car for snow. So I will be pulling an engine and doing my fist set of subaru head gaskets.
Well here is some more info. If you start the car, take the cap off it wants to start pushing coolant out the top of the radiator. Not sure if that's normal, never paid much attention to it. I don't see any bu bled in the overflow, or milky oil. My gut says head gasket but don't want to go down that road unless it completely nessiary.
Hi guys this car is beginning to kick my hind end. Wife was driving from phx to flag and there is a pretty good grade coming north. After creating the grade the temp light began to flash. Looked at it differance in hose temp....changed cap and thermostat. Whent back to phx same thing cam up grade and light started blinking. Also when it does this it pukes coolant from the overflow tank everywere. Tried to "burp" system. When down to phx and it bean doing it going down the hill. Talked to local subui guy and sugested radiator. Put in new radiator, still puking coolant out the overflow. ......which leaves head gaskets or waterpump. Put a block tester on today and couldn't get it to do much, still seemed to remain blue. Is it possible a waterpump could be giving me all this greif? Or do I need to keep testing for head gaskets? Any help would be great. Oh and when I did the block test ran for approx 20 min and removed some of the coolant so as not to get a poor result
