4
Everything posted by jsyme
2 cents: You ask a good question. Let's look at what this is: A wiring harness is a collection of wires. Your harness generally just supplies power and signal everything. It assumes a good ground elsewhere. You can add wires yourself to guarantee good grounds from the battery to chassis ground and between the engine and chassis ground. clean up a spot with a wire brush on a drill and bolt that puppy down with a large gauge wire. troubleshoot the rest.
Leaking valves. What should I do?
jsyme replied to somick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Really? Water? Is the engine on a stand being serviced? The valves should be open and closed based on the phase of each cylinder... -
All these are great suggestions... ^^^ I would say change your oil, and look at the separation in the pan after a day. Antifreeze can go into the oil and emulsify, it doesn't always go into the combustion chamber -or- check your oil stick and look for ugly mayonnaise. Consider the following: Pressure can move from the cylinder to the coolant system, and this can be checked with a bubble chem test at the radiator. It's exhaust going into the coolant. Pressure can move from the coolant system to the cylinder and this will significant white smoke once the engine is warmed up. Pressure can move from the coolant system to the oil and make oil/anit-freeze mix emulsification Pressure can move from the coolant system to the atmosphere in the form of a leak. Pick your favorite.
My hood Release is the same now. It's completely possible. I pulled out the front grill, surprisingly without breaking it, but break it if you have to. Once out you have full control over the hood release switch. Use your right hand to come up behind the verical post and pull the cable actuator to the driver side (USA driver side), while your left hand comes up the left and pulls the hood release lever. -click- -OR- It could be the scenario where the plastic handle broke away from the metal cable. Get a hold of the cable with some fliers and pull.
I have the 1989 GL D/R wagon (which should match that one exactly) and that doesn't look like mine.
Don't forget to paint your key. Paint it Bronco's colors: With the Denver Broncos record standing today at 3 and 3. (The AFC South's Texan's are also 3 and 3.) Pick your poison., but don't forget to paint your key.
Automatic seat belt issues
jsyme replied to XHighOctanex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My Loyale has the speaker wires ready to rock installed in the rear doors, but no the space in the interior panel. So, I just cut them out. They still sound good. I also installed the map light housing running bright white LEDs and I fed it power from the center dome power source. I'm told that the map-light wiring is in the A-Pillar tucked down low, but I opted not to disassemble the interior to fish it out. It works great! One thing about NOT having a moon roof, is that I have more interior room for my 6'1" frame. -
Yep - I "don't prefer" automatic seat belts. The 1992 Loyale has a deteriorating rubber border around that track and it's like a crumbly black tar if it get on my fingers that is tough to wash off. Mine seem to be working fine on the driver and passenger side, but EVERYONE that is unfamiliar with them and rides in the passenger front seat says something about them. If I had to do it again, I would buy the SFI GL over the Loyale wagon. (that and the DR trans.) (and the speaker space in both rear door panels) (and the map lights) (and the moon roof) -
87 gl wagon no power to fuel pump
jsyme replied to Jakethewhite's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Encouraging slap on the back: You can fix it JaketheWhite, just take a more methotical approach. You can do it. I'm hesitant to mention it because of the obvious risks working with fuel and electricity, so no liability on my part... Get the right tools: I highly recommend a powerprobe so you quickly test points with both ground and power stupid fast. Also get enough cable with it so you could potentually test trailer brake lights from the car's battery. Steps: Test everything individually i.e. * test your old fuel pump by itself * test new pump * test the ground wire to chassis from the pump * test the hot wire from the relay to the pump, is it continuous? * test the relay with a continuitiy light and powerprobe Without a powerprobe: * Grab the hot wire from your passenger tail light and extend it down to the fuel pump, turn on your lights and try to start it. * pass/fail you know where to spend your time: fuses, relays, wires, pumps, ignition switch, dead battery, plugged filter, pinched hose, no fuel in tank, bad gas in tank, water in tank, no tank, window tint too dark, unpaid parking tickets, man-made global warming, lieing politicians, that thing you did last summer, you could be on your way to litterally changing the world. * Replace garage fire damage as required Tips: * Presume that you have two (or three) broken pieces instead of one. * PowerProbe has had several model releases. They are all good. Find a mechanic that often "buys the new one", and buy his old one with a 12 pack of beer. -
I think my money is on the IAC valve. (Idle Air control.) Check out this thread: Low cold Idle 93 Loyalehttp://www.ultimatesubaru.org/forum/topic/64199-low-cold-idle-93-loyale/ Here is a generic link to troubleshoot it: https://www.yourmechanic.com/article/how-to-check-an-idle-air-control-valve-by-jerel-lawrence
Is it actually overheating? Cold. Can you start it without touching the gas pedal, and do you hear it idle high<2 minutes> and then slow down when it gets to temp? All without touching the gas pedal?
Spongey Brakes and "Stop Lamp"
jsyme replied to benjamachine's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It still sounds like there is air in the lines. This time bleed the brakes in factory-incorrect farthest-wheel-from-the-master-cylinder-first process <one wheel at a time only>, and attach a clear rubber hose (3/8" ID?) to the bleeder valve captured inside a 1 liter plastic bottle. just leave that valve open and pump some brand new DOT3 through it like a madman. If you're really clever you might find a way to make a change of color (blue) in your reservoir, and once you see that in your bottle, you know you've done a complete fluid replacement in that line. Rinse and repeat 3 more times, and then come back and tell us how happy your are and take a picture of the bottle jig you used. -
Limited slip in '84 Brumby?
jsyme replied to KiwiBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm not familiar with the 1984 Brat (NA/USA) specifically only drivetrains generally. Consider it actually a 2 wheel drive... one of the two front wheels will always pull, and one of the rear two wheels will always pull. presuming the opposite wheel is off the ground or has not traction. (as long as you aren't in reverse where is may bind) (as opposed to say a Honda civic "front wheel drive" where only one wheel actually pulls.) (as opposed to say a Toyota HiLux, (that I want so badly in diesel) with differential lockers, and front-axle lockers, and rear-axle- lockers... that actually is 4x4 and all 4 wheels are pullers. Check out Jeeps Solid axles and Limited Slip differentials if you want a diff-erent experience. -
Not a problem. Test it: You can do the same things with the engine OFF for safety. With the front off the ground, grab a hold of the Passenger front tire and spin it, and you'll notice the driver side wheel spinning the opposite direction. It's the same for the rear wheels. You don't have a solid Axle. What you do have is an internal tranny diff with no locker. Sport guys that want both wheels to turn while one wheel is high off the ground will install diff lockers to make sure both wheels spin when the vehicle is highly articulated. It's nice when off road, but really hard to work with on city streets. It's really frustrating when you want to move forward and all the engine power is going to the wheel that's OFF the ground. = your stuck.
82 Brat: Front wheels wont engage.
jsyme replied to abentz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
My first instinct is a broken transmission. You mentioned AWD instead of 4WD is this the S/R automatic trans and Turbo 1.8? When you drained the transmission fluid, did chunks of metal come out too? -
85 Subaru GL radio questions.
jsyme replied to ErikAnderson's topic in Old Gen.: 80's GL/DL/XT/Loyales...
This will be a shameless plug for my favorite car audio guys Crutchfield.com https://www.crutchfield.com/Car/outfitmycar/mycar.aspx I plugged in your car details and found a Dual branded radio head for $44 and 4" front door speakers for $30 for the pair. I think that fits in your perfect world scenario where elected politicians make wise decisions. What makes these folks standout is that they make available radio to car adapters wiring kits and Install checklists with the new Radio Bezel for your car available as a kit. I have two of these cars and put extra speakers in both. The Loyale is a pill because the rear doors do not have the space cut out for speakers in the interior door panels. The speaker wiring is there and ready to be used. Remember to never let the speaker frames ground to the car chassis ground. Have fun. -
Hola Two ideas: 1. Use your smartphone app called Google translate and point it at Japanese words and App will translated them on the fly. 2. Here is a picture of my fuse panel 1992 Loyale Wagon 1.8 SPFI non turbo https://imgur.com/xahrG0C
Car won't run after sitting in the rain
jsyme replied to Krivman65's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hmm.. Runs with full lights for time X. battery expires and sits. no juice means no fuel pump prime up on key turn, after battery revives after sitting all night. Dead alternator? / dead battery combo? -
Wiring do's and don'ts: A guide
jsyme replied to skishop69's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Bad monkey! No banana! Too funny -
Well, clearly from the picture you can tell it's an automatic. When I limped mine into the parts store I was hoping for just any old belt, at the time I guess I might be willing to part with $4 maybe $5 USD tops. $$ 25 !! $$25 EACH!! ...and that's the story of how I run Gates belts. They make my engine round and round. I don't really care. it works.
- 11 replies
- Alternator belt
- Accessory belt
(and 3 more)
Tagged with:
The 1988 DL/GL wagon is considered the 3rd generation, where the DL is a cheaper trim with roll up windows, and the GL is a higher trim line with all electric windows, locks and mirrors. All Front Brake Calipers (and holders) between GLs, DLs, Loyales and both sedans and wagons will fit each other from 1985 to 1994. Impreza and Legacy will not fit.
Well the 86 and 88 Engine difference is carb vs. fuel injection, vacuum hoses, loom or wiring harness and fuel pump pressures. https://en.wikipedia.org/wiki/Subaru_Leone https://en.wikipedia.org/wiki/Subaru_EA_engine You may have an EA71 or an EA82 engine. As as owner's guide it's probably exactly the same. If it's a Haynes or Chilton's manual it's mostly correct. And the most change will be found in the Subaru Service manual for 1986 and 1988. If your book is a copy of Stephenie Meyer's "Twilight", I think we can all agree that the Owner's manual is still a better romantic novel. If your book is the Bible, God's Word never changes, and He loves you very much. Nothing changed between 88 BC and 86 BC If your book is George Orwell's "Nineteen Eighty Four" both engines are carb'ed and it doesn't matter because you're living in perpetual war under omnipresent government surveillance. If your book is actually an 1988 newspaper President Ronald Reagan is the most powerful man in the world and we have a reason as to why the Speedometer runs best at 55 MPH in 5th gear in the NA. What is your book?
