5
Craigar last won the day on March 21 2025
Craigar had the most liked content!
Gender
Male
Location
Lawndale, CA
Occupation
PC Service & Web design, semi-pro musician
Referral
diggin on the web!
Biography
rebuilt my first (lawnmower) engine about 49 years ago, when I was 10... done a few VW and motorcycles but getting tired of repairing stuff thats tricky or real PITA...
Vehicles
93 Loyale Wagon EA82 SPFI , 3AT
Recent Profile Visitors
1292 profile views
Craigar's Achievements
USMB is life! (4/11)
31
The smog guy also showed me that the black rubber tube on the bottom of the Evap canister doesn't connect to anything - it's just dangling.. and I can't figure out where it should go , but he says that sub system tests OK so he can ignore it..? Thanks again Craig Edit 1 hour later : This post says it's a dangler i.e. goes nowhere - except maybe in the hole in the frame, and I see a hole on the frame I could stick it in .. so I'll stuff it in.. https://www.ultimatesubaru.org/forum/topic/36898-quickeasy-charcoal-canister-question/#comment-297552
Thank You SuspiciousPizza for the update that it is also used in a California SPFI EA82 Yea this sensor isn't listed - or any egt sensor - for an EA82 (at least not at RockAuto or Fleabay, google search) nor do I see it in any of the exploded intake manifold views.. but it looks about identical to this one https://www.rockauto.com/en/catalog/subaru,1994,impreza,1.8l+h4,1268861,exhaust+&+emission,exhaust+gas+temperature+(egt)+sensor,17051
Do these fail often? I R & R it when replacing intake manifold gaskets and it had a fair amount of carbon buildup so I gently scraped off most of it and I don't have a "check engine light" problem, and this car has passed smog 3 times so far. It runs good and seems to be getting OK mileage, has about 155K miles no smoke or steam coming out of exhaust, plugs look good also. This image is from a 1994 Impreza but seems to have same exact motor i.e. 1.8L H4 it goes in the threaded hole to the left of this brass stand off (passenger side of intake manifold) Thanks Craig
EA82 replacing manifold gaskets
Craigar replied to Craigar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Got it all back together, driving it for a few weeks and runs maybe even better than before - sounds much better without the worn out water pump rattling - , no leaks! BUT didn't pass CA smog (engine light is off when motor is running) and was 2 degrees to advanced so reset it and ran a bottle of " CRC Emissions System Cleaner" .. double your money back... in a half tank of gas so going to try to pass test again. Thanks everybody for the support -
Thank you! The bolts didn't break probably cause they're hardened or tempered, they have a #7 on the top of the bolts. Yea first I'm going to hit the bolts and threads with a wire wheel but probably use a die on this particularly bad rusted one - the rest didn't look as bad - 3 of them came out easily. Will see Started a new topic for doing the gaskets and hopefully getting it back together without putting some of the spaghetti back in the wrong holes.. https://www.ultimatesubaru.org/forum/topic/186408-ea82-replacing-manifold-gaskets
after getting the bolts out (serious slow torture on the rusted encrusted ones https://www.ultimatesubaru.org/forum/topic/186067-any-new-ideas-for-the-old-intake-manifold-stuck-bolt-problem ) then had to clean up the surfaces - the right side was so pitted I ended up taking it down with a medium diamond hone. The first and second image are from just scraping it with a sharp putty knife and carefully filing with a old "cross hatch" file - not happy.. so I worked it for about 3 minutes total with this medium diamond hone. Walla! did the same to the bottom of the manifold - but only removed what lines, pipes,sm0g stuff, etc. I needed to in order to lift it up only a few inches, so I had to use my selfie camera and it doesn't focus (kinda like my eyes now ) as I'm hoding the cell phone camera facing up .. kinda like holding a minature yoga pose Here's a couple of images using a "dental mirror" showing the ends of the manifold's water galley, I think I need to clean it up more BUT it was getting too cold and the wind and fog were rolling in.. .. and before I stuffed the sock in the intake port I looked down into it and I see a pile of "oxide crystals" so I'm going to make sure that intake valve is closed and try to get a skinny rubber hose attached to a vacuum cleaner down past it and knock most of it lose with a chopstick .. if yea all think that's a good idea?
Got em all out without breaking any - I don't think Ive stripped the holes either but haven't cleaned it up yet. For this really tough bolt I decided to use a "paint stripper" heat gun on high for about 15 minutes and it still wouldn't budge so drilled a 2nd hole down closer to the threads, earlier had drilled a hole about in the middle of the column to get the penetrating oil down into the crud in the bottom inch of the column also. After drilling this second hole and then using a lot of penetrating oil, then heat, I had progress had to heat up down by the head for at least 10 minutes with paint stripper heat gun, that's why my aluminum shield has turned golden brown .. I tried a M.A.P. torch but it was to scary and causing way to much smoke for my comfort.. and wiggled back and forth tell I could get about 1/4 turn, came back next day tried it cold no t so much movement so heated it up again and kept working it back and forth - but not going as far in as out.. then add more sauce.. do it again and eventually.. Here's the bolt right after I got it out - I used a lot of B'laster penetration oil, and couldn't get it moving with the 3/8" impact gun - had to really push and pull on this ratchet - really hoping the bolt wouldn't break,, kind of amazed it didn't
.. and about a week ago I sprayed em with my 20 year spray can of Liquid Wrench, - which I discovered 3 days ago had lost all it's pressure probably cause I unknowingly banged the head on it, probably shutting the hood.. So I bought a new spray can of B'laster and sprayed and soaked it a few more days - no cigar So here's the specs of a very nice portable 3/8" torque wrench I just bought from Home Depot on sale for $140 with battery and charger Lightweight Design. Heavyweight Performance. Pair with MAX Output batteries for maximum power Industry’s most compact Powerful Brushless Motor delivers 250 ft./lbs. of breakaway torque 3 speeds + auto-tightening mode provides adjustable power and speed Auto-tightening auto-stops when fastening to prevent over tightening bolts Auto-tightening in reverse, delivers full breakaway torque, then stops when the bolt is loose Tri-Beam LED enhances visibility and provides even distribution of light Compatible with RIDGID’s AC13B04N Impact Wrench protective boot (sold separately) 100% Compatible: Works with all RIDGID 18V Batteries, Tools, and Chargers Lifetime Service Agreement with registration within 90 days Includes: R872071 18V SubCompact Brushless 4-Mode 3/8 in. Impact Wrench, R87002 2.0 Ah battery, charger, belt hook with screw, and tool bag RIDGID: Build for a Lifetime 18V SubCompact Brushless Cordless 3/8 in. Impact Wrench Kit with 2.0 Ah Battery, Charger, and Bag and it didn't seem to move any of em at full torque, even trying in both directions.. So I cleaned the oil + road dirt mix off the passenger side intake manifold area (to lessen the chance of a bon fire) and only M.A.P. torched it for about 3 minutes total cause I've never done it before and was getting smoke and embers and nervous and cold and it was now dark outside where I'm working on it and the crappy harbor freight "free head lamp" was turning off all on it's own way to much - even after messing with it a lot.... and "amazing to me " got the bolt loose closest to the windshield loose! BUT it didn't want to go "looser" and "tighter" back and forth ( CCW and CW ) only looser so went about 2 turns and going to give it chance to soak more over night. - and the head wasn't really very hot, maybe 110 F. Progress, not perfection ... One down, two to go Grrrr ,, I mean "patience..."
Well I didn't even think about a rethread kit but you say that making me think it's inevitable so when and if I gracefully get these bolts out it'll probably need to be rethreaded with maybe some bigger threads or you got to put in like a helicoil and for heating it up with a torch should I use a map torch or a propane torch, any preferences? Thanks
I was gone for about 2 months and I finally got back to working on this car and ended up drilling a small hole on the outside corner of the manifold where the bolt goes down to try to get penetrating fluid or blaster down in there and then went and got myself a modern 225 foot pound max rigid torque wrench gun and I haven't broke any of the 3 bolts loose yet, so I guess I gotta go get me M.A.P. Torch, thanks for the good suggestions.
Drilled through stuck intake bolt... and head bolt.
Craigar replied to Corvid's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank You! The little plate under this particular bolt can move so the head isn't stuck at least not to the top of the landing (don't know about passenger side yet) and I also thought of the "drill a hole for the spray lube straw into the corrosion cavity" sounds like a really good option! I started a new topic here https://www.ultimatesubaru.org/forum/topic/186067-any-new-ideas-for-the-old-intake-manifold-stuck-bolt-problem/ -
93 Loyale EA82 SPFI Whilst replacing my water pump etc. I discovered another problem - the right side (by alternator) intake manifold is leaking coolant, which I suspected for a few years.. and the back long bolt is stuck / frozen - and so are the 2 long ones on the passenger/left side also... I soaked their heads and around the gasket (where we need really need it but probably can't get past the gasket) with liquid wrench and have to take care of other business so it will be a month before I can get back to it. Read through lots of good ideas for stuck bolts BUT these long intake manifold bolts have the head of the bolt more than an inch and a half from the stuck threads going into the head so I don't think many of those ideas will work. I'm thinking a 6 point impact socket, impact wrench and maybe first drilling a small hole into the manifold close to the base of the bolt, about a quarter inch above the head that I can load up with some fancy "nut buster" sauce, I have liquid wrench from 20 years ago but maybe their is something a lot better now? Here's some good ones https://www.ultimatesubaru.org/forum/topic/44039-what-are-my-options-with-this-stuck-bolt/#comment-354824
93 Loyale SPFI.. the back long bolt driver side intake manifold bolt is stuck / frozen - and so are the 2 long ones on the passenger/left side also... I havn't broke them off ( yet ) .. any easy way out? thanks all Craig
