Hi all,
I bought this Brat 8 years ago, already swapped. A couple of months ago, I found a dead battery. I charged it, Brat started right up. Battery that came with the Brat, so at least 8 years old. In the process, I checked and found the alternator not charging. New alternator, also not charging. Returned new alternator. Took original alternator to shop. Found out exciter is not getting voltage to start charging. I have now replaced the battery, still not charging from alternator. I have a 3 wire plug in the top of the alternator. Thick white wire is 12.10V. Yellow wire, 0v. Black wire red tracer, 0V.
I think white wire is battery voltage and Yellow wire is 12v switched. Not sure on the black/red wire. I can “force” the alternator to charge by jumping battery to white wire pin and a 12v switched source.
I have seen a few threads about a battery light in the dash being in one of the small lines. Gauges and lights attached in the dash have never worked. All fuses are good. I would like to run the original wiring if possible. Anyone know what the yellow and black wires go to in a swapped Brat? Do they splice into the Brat harness or stay separate?
