Yellowbugeye03
Everything posted by Yellowbugeye03
94 loyale need help with egr
Yellowbugeye03 replied to Yellowbugeye03's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks like that's gunna wait till I pull the motor this summer to do some gaskets and seals thay are leaking -
Well I know the valve wasn't operating correctly like I said it was stuck open but maybe now IL check the pipe and see how blocked it is if I can get it off if I remember correctly I couldn't last time I tried taking it off -
Update: new egr valve helped but still getting code 55 on cold start up and takes a couple minutes to go out, but doesn't buck nearly as bad anymore -
Also after I cleaned it it still wouldn't close all the way. Im relatively new to these cars always had subarus just not this old. If this helps when I start the car in the cold it's hard to start takes a couple times to turn it over holding the throttle about half way. Then once it's started the check engine light comes on code 55 but it turns off after a couple minutes and it runs fine but if I try to take off before the light goes out it bucks -
I took it off to clean it and its stuck open -
I bought a new egr valve today and it requires you put the correct orifice washer in according the the stamp on the oe egr, the problem I have is I'm pretty sure the previous owner replaced the egr with one off an xt6. So I was just wondering if anyone knew the stamping number of the original
4x140 to 5x100 bolt pattern adapters
Yellowbugeye03 replied to matts87glsedan's topic in Products for your Subaru
Sorry to bring up an old thread but is this still a thing? -
94 loyale front axle trouble
Ah i gotcha i figured out what you ment after i thought about it ill see if thag works -
Do you have a picture of said shade tree tool im interested lol just cant picture it -
I tried that i dont have a long enough small punch unfortunatly. It is a manual trans though so they arnt like newer modles where the axle stub is held in by a circlip. That stinks i eould much rather do this on a bench -
Is there anyway to remove the front axle stubs from the transmission i have a broken punch in my axle stub from the previous owner and it would be easier to remove on a bench than under the car
My guess is when I had the intake mani off and was cleaning the matting surfaces some of the coolant from the coolant passage got into the head or something along those lines without me realizing it, runs good now though better than when I got it and no check engine light. Gunna do the ignition timing today after work and see where that gets me
