milty60
About milty60
  • Birthday 10/17/1960
  • Gender
    Male
  • Location
    Danbury CT
  • Occupation
    IT
  • Referral
    searching Google
  • Biography
    DIY for all my engine powered equipment and anything technology
  • Vehicles
    2009 Suby Forester manual 240K
Recent Profile Visitors
825 profile views
milty60's Achievements
USMB is life!
USMB is life! (4/11)
7
  1. Appreciate all the info - may spend money to get a suby center diff (AWD is best in Northeast but part here is $500) also like the idea of making it a FWD - do you guys agree that's doable? No harm to the tranny? Son is thinking about getting a replacement car - this ones got 250K on it - not sure how long its going to last. May dump in $500 now and something else goes in a number of months. Thanks, Milty
  2. So the viscous seizes up once the car is at 30 min plus drive time. Do the plates lock up and cause the torque bind issue? $500 bucks new one out my way. Saw a couple on Ebay. Are there rebuilds, chancy getting a junk yard one. Not rebuild-able by a Diyer? Thanks, Milty
  3. I should replace the entire center differential - the viscous coupler is a component in the diff - when that component is bad it causes the torque bind? Found a youtube video - looks doable - take some time been working on cars since I was 16 - almost 60 - my son will help. Here's the video. How much time do I have? - its been doing this odd behavior for a few months - no other drive-ability issues. Thanks, Milty
  4. Power steering fluid is normal. No check engine light. Most recent behavior after a half an hour of car driving (does not occur when car is cold) when I back out of a parking spot, I don't hear any noise but it feels like I have a bubble in the tire every six inches around the circumference. This happens each time I back out of a parking spot with steering wheel turned right or left - never a noise or sensation when backing out straight - only on moderate to tight right or left turn. Advice? Thanks, Milty
  5. Tight circular turn front end noise and odd sensation in steering wheel. What is this? https://youtu.be/E-N4K76KhlE https://www.youtube.com/watch?v=m3ghtNkihVA https://www.youtube.com/watch?v=TCyIbmSyVK0 Thanks Milty
  6. I replaced the Relay a while back - idle is stepped up a bit. I still have codes to investigate although the car does not seem to show any ill effect due to codes - at some point I will get hit with an emissions check from DMV and will have to get that light off and/or issues fixed. I still have these codes: 2 current faults - P0204 powertrain injector circuit - cylinder 4, and P3100 powertrain, also 2 pending faults - P0104 powertrain mass or volume air flow circuit intermittent - P2000 Powertrain - NOx trap efficiency below threshold bank 1. I cleaned the MAF with designate cleaner - still getting code. Any thoughts on codes? I wonder if I have a short somewhere causing one or all of those codes? Thanks, Milty
  7. Sounds right - wrong bolt. Actually, when I removed a couple of washers the bolt tightened to my comfort level - its been holding tight since starter motor install. Thanks, Milty
  8. Replaced the starter motor on my son’s car over the weekend – its never been replaced looks like original Suby starter. Came out fairly easy – top and bottom bolt needed some muscle to break free but not bad. Top bolt has 2 washers and a lock washer and a bracket that the ground cable attaches to. I finger tightened the top and bottom bolt. When I used the ratchet on the top bolt as it became tight I could hear and feel … I’ll call it a skip and a click – it would not tighten beyond this point … ground bracket still loose – I said to my son oh S*it now it needs to be drilled out and heli-coiled in a very tough spot to do this – probably need to tow to a machine shop. I took the bolt out and at the very bottom could see for just about a quarter-inch – metal threads surrounding the bolt – bolt undamaged - unscrewed thread from bolt – assume this is the internal threads in the mount that were broken free – somehow? So, I said it seems like a lot of washers on this mounting bolt – I removed the thickest one and said hopefully the bolt will go in a bit deeper and catch some good thread – thank the Subaru Gods – it did – tightened up nice – I’ve rechecked it a few days after long runs with the car to get it up to temp so motor etc can shrink/expand – no issues. I can’t believe I would have stripped or cross-threaded the hole – was it just time to for the bolt hole to loose threads? The manual tranny was replaced 6 months back by neighborhood DIYer I think this bolt is one of the bolts that mounts tranny to the engine but I need to look closer – did the DIT guys over tighten the bolt then? Thoughts? Thanks, Milty 09 Forester manual 250K
  9. Cleaned MAF sensor and connector - cleared code p0104 - it's back - I don't detect any drivability issues but need advice on resolving check engine P0104 code. Thanks, Milty
  10. Cleared codes - 1 code came back P0104 - MAF circuit - I'm going to purchase the MAF cleaner and also reseat the electrical connector. Then, clear codes again see if it comes back. Any advice? Thanks, Milty
  11. Showed Subaru parts guy multiple wiring diagrams and pictures of fuse box – finally got correct relay – swapped it out – cleared codes but codes came back a few hours later – haven’t checked with odbc tool but assume same codes – will check this weekend. I don’t detect any issues with the car at this time – idle is steady – sits around 650 – no stalls – hesitation – power loss. Trying to decide my next steps for those codes? Thanks, Milty
  12. Pulled relay that was marked in picture - has a number on it 156?8-3818 - below it a - V - I must of scratched the one number off trying to get the relay out it was tough to remove - its mounted flush in fusebox - couple of clips on both sides - I called Subaru parts - guy said that number is only a casting number - he tried to locate it on his diagrams - but could not find a "Main Relay" so I plan on pulling it over the weekend and taking it in - he said he should be able to match it up then - can't believe how tough this is to identify - not feeling super confident he will identify it - I see two other relays in that fuse box that are identical to this one. ________________________________________________________________________________________________ I'm going to pick up the cooling system conditioner and give it a try for temp fix to my leak problem. Thanks, Milty
  13. I found a relay fuse box under the glove box and more relays next to the fuse box under the dash on the driver's side - still not sure which relay is the "Main relay" See photos Thanks, Milty
  14. I replaced hose throttle body to heater hose tubing - no leak at hose - but a very slow drip is coming somewhere at T connection on heather tubing that travels over intake manifold to behind timing belt area. Can I use a stop leak to temporarily fix. Looks like a nightmare to replace tubing. Thanks, Bob
