I am hopeful the world will keep turning, a little longer anyway. Pulled the water pump and found some liquid gasket inside, the same sashay appeared to be keeping the thermostat from seating properly. Hosed out the radiator and the engine block. Cut a new gasket for the pump and the thermostat housing.fixing to reassemble the cooling system and make a run to Vegas. Also, replaced all four plugs, gasped at 1.07mm. The old ones were white! Time to research how to locate and adjust the fuel air ratio I suppose and get her not only cooling proper, but running proper as well. A manual was just ordered. Looking forward to a tangible guide to my new Subie!. As for the fan, it does work. Both the primary and secondary both function. If she is running hot, wiring the secondary fan to the same circuit as the primary may help cool her down, leaving the cause of her overheating unaddressed. I appreciate the inquiry and the indicators of severe damage turbosubarubrat.
