superu
    4
Everything posted by superu
  1. Basically you want to take up some of that taller collar that the FOR shock has where the IMP collar is rather small...
    That way the nut clamps down on the threads, and sandwiches the the washer (seated on the thicker part of the shock collar) to the tophat. Without the washer, the nut runs out of thread before it clamps the tophat onto the shock, thus the clunk as the tophat has play over the taller part of the FOR shock's collar. . .
    Take your strut to the parts or hardware store and test-fit them...
  2. Hey,
    About the washer. I think (from memory of like 6 years ago) it needs to be like 5mm? thick or so.
    When you take the tophat off, here's what you'll see:
    picture.php?albumid=191&pictureid=1763
    and here is the shock from a 99 FOR strut.
    picture.php?albumid=191&pictureid=1764
    I do not remember the size of washer I got, but it needs to have an opening big enough for the shock stud, but to seat around that collar, but not TOO big to interfere with the bottom side of the tophat.
    I know other folks have gotten washers that that are thick enough then drilled or drimmeled out the whole so it's wide enough to fit over the shock stud, yet seat ON the thicker part of the shock stud's collar.
    Does that make sense??
  3. Yup, that's a lot a postin'! nice work! checkit! MY post count is LOW for how long I've been here... @ .24/day
  4. Nice job, it looks great! Do you have an automatic or manual? I forget if you mentioned it earlier in the thread.
  5. I've always wondered how post counts like that are even possible. . . . but well done, however it's done
  6. I have to say it. . . . "Ahh, Moab, my back yard. . . :brow:"
  7. My friend gets 12ish in his 4" lifted 96 cruiser (with the in-line 6... the 8's came out the following year/model change) for what that's worth, but I hear ya on the MPG.. I mean I'm rolling around 22-26 BUT it's no rock crawling yota, but pretty capable for a car that I drive enough to appreciate 26 mpg.. AND, you should check out the NEW cruiser being released in, go figure of coarse, Australia... the Toyota advertisements say it's for people who abuse their trucks... or something like that! http://www.autoblog.com/2011/11/11/toyota-releases-extra-tough-land-cruiser-gx-for-australia/ http://www.egmcartech.com/2011/11/12/australia-gets-extra-tough-toyota-land-cruiser-gx/ AWESOME!!!
  8. that's purdy! Nice work Gregg!
  9. Woah!! a regasketed engine in 2 days from the last post!!? :-p I like that, with your trimming, you kept the pinstriping
  10. I've run cooper discoverer ATs, BFG AT TA/KOs, and now have the grabber AT2s. Nearly identical tread pattern as the BFGs, but the grabbers have a bit more space b/t the lugs, so better shedding/clearing. AND about 20% le$$! I've only had them 10K or less miles, but love them so far. looking forward to another winter in them, but with better gearing now I'll better able to test them this year. cooper (205x75x14...don't think they make this size anymore, and maybe not this style either?) BFG all terrain TA/KO (27x8.5 14") general grabber AT2 (27x8.5 14")
  11. lift! skidplate! tires (snow tires, either studded, studless, or studded ATs)! gearing (for a manual)! torque (4.11's or better for a stick)! emergency kit! recovery kit! spare fuel! courage! blankets! boots! spare jackets/layers!
  12. I had questions on OB vs. FOR springs and finally answered my own question. i hope someone can chime in with a side-by-side of OB and FOR struts. But these threads show OB and FOR springs, among other bits of detail. . . http://www.ultimatesubaru.org/forum/showthread.php?t=105009&page=2 http://www.subaruoutback.org/forums/85-all-other-subaru-models/21168-taller-forester-springs-outback-springs-3.html http://www.subaruoutback.org/forums/81-wheels-tires-brakes-suspension/17450-using-forester-springs-struts-shocks-lift-1st-gen-outbacks.html
  13. Ahh, I guess that makes sense that w/o the crossmember spacers, I wouldn't need the longer coupling. . . DUH! thanks man Yeah, i get what you're saying about tooth count and being finer... like thread pitch, but with respect to gear teeth...in affect.
  14. Glad to help! This info wasn't around or as common when I did my swap 7 yrs ago, so I can totally appreciate your position!! I think I got those (in my post above, and photo here) from tirerack.com. I think If you got the whole assemblies you won't need to bust apart the fronts, just rent a strut spring compressor from your parts store and compress the spring on the rears to swap out the top hat. The spring perch is only needed for the front (if you do weird things like add FOR springs to OB struts, etc....) and the upper spring perch for the rear is part of the top hat. This is why FOR spring perch with FOR spring and NOT OB perch with FOR spring... You can see the top of the FOR spring gets smaller, OB doesn't... I do NOT know for sure if 2nd gen FOR do this, but no matter, since you have the complete assemblies! But again, if you got the whole assemblies, your don't need to worry about it.. Here's a repair manual diagram though for your edification. #2 os the "tophat" #4 is the upper spring perch (for the front.. the rear perch is integrated with the tophat) could be a blown shifter linkage. The part which connects the shifter with the rod that comes out of the tranny. Mine went and the shifter floated around quite a bit. When in 3rd, the stick looked like it was in 1st. . . It's the rubber grommets that blew out... ...... looked a bunch but couldn't find a pic of the universalish-joint looking thing where the rubber grommets go in... I might have a newer linkage I can take a pic of though to give you an idea of what to look for when you crawl under your car and look up.. . . .
  15. Are you referring to the double U-joint shaft which links the steering column to the rack itself? I just got one from a gen 1 OB (the longer one), since I've still been running with the stock legacy shorty... this is a lifted application, BTW I suppose that short coupler could be adding stress and strain to the system, considering my hub-fender is 2-2.25" taller than stock with my strut/spring lift combo. . . But that's a good thing for me to consider, thanks for that...
  16. SAHWWEEET!! Good info guys, thanks a bunch!!! I'll look into it then!! This really opens the opportunities for re-replacing a leaky rack. gen 1 legacy turbo (1st choice, but ooooolder), or ANY Impreza-based platform rack, right?
  17. I'm curious for opinions and experiences with compatability of an impreza-based steering rack into a 2nd gen legacy. . . I swapped a 98 LGT rack into my 95 legacy last year and now that one is leaking like a sieve too (the origional reason for swapping the stock one). So I'm curious if any of the imprezas racks could be swappable too, like maybe a WRX rack. My gut says no, but that's just an impulse... I know some RS bumpers fit on 2nd gen legacies so it wonder if the steering internals might bolt-up too.. thanks
  18. In the US, the only EJ20s we got were turbos, so I don't think we can attest to longevity, since they're all in WRXs... I'm pretty sure Australia had naturally aspirated EJ20s in a lot of cars for a long time (probably the same setup there in Austria). I know foresters had EJ20s into the late 90's early 2000s. . . US NA EJ22s are simeclosed decks (I think), but the early gen turbo EJss wasa closed deck, so I think THAT would the bullet-proof EJ block. Especially since it only ran like 8 pounds of boost. But it was OBDI, so not tunable or easily modifiable. . .
  19. As I understand it (and figured out with trials), you get the scavenging with the "Y" pipe snd the backpressure with the cats, then open it up and you'll be fine. BUT really, all you get is better notes and no real gains with a wider free-er exhaust on a NA EJ22 engine.... I'm running stock "Y" pipe and cats, then opened up to 2.25" exhaust through a 12" cherry bomb then a magnaflow (which is pretty much an open muffler). The wider pipe and cherry bomb in place of the factory resonator) give it a deeper note and the magnaflow quiets it a bit at idle, but lets you hear the deeper note on revving... BUT it's NOT tinny at all. that's a honda and dynaflow characteristic. I think I have a youtube or picasa video somewhere, but they still don't represent the deeper note very well. . . . . don't hold your breath for it though, I'm not sure I can find it quickly.
  20. I'd assume so. I haven't had a 2nd gen FOR strut in hand but I did figure out how to do the washer trick on the 1st gen FOR strut, after the install and thunking... This is the IMP strut collar This is the 98 (1st gen ) FOR strut collar So that's where you'd put the washer, to take up that extra collar length... This shows the rear trailing arm bracket out of my legacy (your IMP should be similar) and an OB bracket (FOR should be similar) I think this IMP is on 2nd gen FOR strut assemblies....... it might be OB and blocks, but I can't remember. . . At any rate, it's pretty badass!! Also check here for good info and photos http://forums.nasioc.com/forums/showthread.php?t=2166272 Ciao and good luck!!
