Gender
Not Telling
Location
Goldendale washington
Referral
Google
Biography
I like to party
Vehicles
90 loyale
Swmonteton's Achievements
Member (2/11)
2
Thanks guys I'll probably turn the strut blocks so they face the fenders next week. I have a loose tie rod I'm gowing to replace along with the a arm bushings aswell . Took it for a lil 4x4 today lot of fun but hell is that car gutless going up some steep hill sides. I got an ej25d along with a fly wheel and spacer plate . Was going to send in the wiring harnesses to have them spliced sometime in the next few weeks. Hopefully get that motor in there sometime by November. Should be a really nice rig to drive in the snow once everything gets put back together. No pics again but will post some soon of the spacers I installed soon. Cheers and thanks again
Put spacers under the shift linkage no more rubbing on the body. Put spacers under the driveline support no more rubbing on body. Found a bunch of loose bouts all over the place tightened everything I found. Car drives so much better now. It's getting dark now and ran out of gas on my pressure washer so it's so dirty down there it's difficult to tell what is what. If any one can point me in the right direction on the positive camber that would be cool . I did not have time to call sjrlifts this week.
Figured out the bushing on the shift linkage saw someone replace the bushing with a piece of rectangular tube steel. Found out the missing piece in my last post was some sort of cross member presuming they deleted it after the lift going to try to fabricate something that will fit . Detected another problem sound the drive line was hitting the bottom of the body going to put some spacers in there give it some more clearance. I'm going to take the pressure washer out there today and clean off the bottom with some super clean . I'll be able to take better pics I'll try to get as many as I can so any one can see what I did. ...getting some sort of popping sound from passenger side front wheel . I'll take some pics as well . There is a bushing that is toast . Actually pretty much every thing rubber on the car is toast. I'm hoping after replacing all the rubber might fix the sound ....was thinking it might be a strut too? I'm going to drive it around the property and see exactly what kind of popping and In what intervals it occurs .
And while I got u guys here I'm I missing something or was this deleted because of lift. I'm talking about what looks like a support bar went over or under the exhaust there are to bolt holes on either side.
Also when I go over large bumps I get a loud popiping from shift gear from hitting body looks like that lititle square rubber piece is cracked and splitting could that be the culprit?
Should I run smaller tires? I get a lot of rub too lt235/75r16 is on it now. What is recommended size
Is this even a six " lift?
Looking how the cups that hold the spring are not Flat I could see how rotating them could possibly fix the problem
I'm pretty newbie at suspension work could the springs be to big maybe the wrong size struts? It's only in the front end back looks fine
I read that the struts might need turned 180 °
Trying to get pics up
