Everything posted by Foresturrr
Yeah, the problem is definitely not in the brakes, axles or even the driveshaft.I've finally ruled that stuff out by this point. I've got my $ set on buying a new (used) trans because it's definitely internal. I'm going to drain the front diff in the next few days and prepare for the carnage...
- 16 replies
- transmission
- repair
(and 5 more)
Tagged with:
I can try to power brake it, but since the wheels aren't going to move I doubt it will do it. From all test I've done, it only does it when the wheels spin.
- 16 replies
- transmission
- repair
(and 5 more)
Tagged with:
It makes the exact same noise in any forward gear or reverse. When you apply the brakes to slow it down, the noise gets louder and more harsh as it slows down until the wheels stop moving. I haven't tried to power brake it.
- 16 replies
- transmission
- repair
(and 5 more)
Tagged with:
I'm trying to go into as much detail as possible in explaining the noise and the tests that I've done. Sitting in my garage with all wheels on ground as you would drive it, idling or being revved in Park, no noise at all. Put car in any forward gear or reverse, go to move even a foot and clunk, clunk as it moves. Same as with the car on jackstands and all wheels off the ground. If you put it in gear and wheels start spinning, clunk clunk. That's how it's being tested in the video, on jackstands.
- 16 replies
- transmission
- repair
(and 5 more)
Tagged with:
Yes, it's BAD! I checked all cv axles first, that's why I ended up replacing the front pass one. All others seemed to be fine, no excessive play, ripped boots, etc. I checked the drive shaft for play and it seemed to be ok from what I know. Trans fluid is at the right level, but I haven't drained it, the diff fluid or anything like that yet.
- 16 replies
- transmission
- repair
(and 5 more)
Tagged with:
Without watching the video, I'm not sure if you'll get a full understanding of just how bad a sound this is... I've looked up every video I can find on cars with a bad axle, drive shaft, differential noises, etc. and all fail in comparison to this. I don't know how to explain it, other than say a cv axle broke in half and one half was still in the trans turning while driving knocking against the body... clunk, clunk (very loud) with each rotation.
- 16 replies
- transmission
- repair
(and 5 more)
Tagged with:
Crazy thing is as bad as it looks and sounds, it would still drive and shift perfect.
- 16 replies
- transmission
- repair
(and 5 more)
Tagged with:
I haven't drained the fluid or did any further inspection of it.
- 16 replies
- transmission
- repair
(and 5 more)
Tagged with:
I have a 2001 Subaru Forester L with auto trans. I started hearing a really loud clunking noise (as the wheels turn) as I was driving near my house. I immediately took it back to my garage. The noise is very brutal, as in something is ready to break and break badly. The motor and everything jerks pretty bad with the noise while the wheels are rotating. First inspection, it had a really bad busted inner CV joint on the passenger side front, which I noticed had lots of play. Replaced with a new axle, but the problem is still there, no change at all. It really sounds like the noise is coming from inside the transmission, like the front differential is ready to go??? It only makes the noise when running in gear while driving or with all wheels lifted off the ground. It doesn't seem to make the noise / jerk when turning the wheels by hand. I took a rather large video (over 150MB) so I'll provide a link to the video below, any help would greatly be appreciated. https://sendvid.com/om7qyxz4
- 16 replies
- transmission
- repair
(and 5 more)
Tagged with:
