Kwiknez
Everything posted by Kwiknez
  1. Hello everyone, I have a line on a jdm ej20 for a good price and I am wondering for the swap do I need to do anything to computer or can I just swap in engine and tranny from the Wrx. Thanks for help
  2. If carbed it might be accelerator pump perhaps
  3. Check your front catalytic converter. I had a similar problem awhile back and replacing the cat fixed the problem.
  4. Yeah I would love a set, but a bit rich for me, $600 for wheels ouch, especially on $500 car haha
  5. These look good if you can afford them http://get-primitive.com/wheels-rally-race-street/466-bratbrumbygl-wheels.html
  6. What kind of problems is it having? Wish mine was the turbo instead of base carb version. Is it dual range or push button? Good luck.
  7. Might have to stick with the 13's until you decide to drill hubs or get lucky enough to find some Peugeot 505 wheels that are bigger.
  8. Any particular models that you can think of? Toyota?
  9. Hi people, I have been searching around for a good tubular front and rear bumper replacement, has anyone retrofitted one from a different car and made it work. I have had no luck locating one that fits directly. I see them all over the place on different cars and I am sure something would work just not sure about mounting points etc. Thanks
  10. Thanks for response. I know that 23 spline is needed. I just need to know if the shorter distance between boots on the mfi compared to carb would be a problem.
  11. Hello, I was scrounging around at local junkyard and found a 88 GL that was pretty decent, grabbed a few parts of course, I saw that someone had taken out the transmission and left the cv axles on the backseat floor. Being that my cv's need new inner and out boots I was considering picking these up and just rebooting them and installing, my quandary is I read that the cv in mfi is different than carb. Spline is the same but the distance between boots is different. Does that matter?
  12. Fixed. All along the cat was plugged and pretty broke inside. Replaced with new Y pipe and cat and voila instant power.
  13. As far as I know 3.5 backspace is pretty close to stock. Might need others with more experience to chime in on that.
  14. Here is a list I found. s22.postimg.org/gps5g1ohd/image.png
  15. Toyota 4Runner 80-95 15x7 4.50 backspace Isuzu Trooper 84-91 15x6 3.50 backspace Isuzu Trooper 92-96 16x7 3.50 backspace Isuzu Amigo 89-00 15x6 3.50 backspace Just to name a few, hope this helps some.
  16. Thanks to Machineit I was able to try out a new carb to see if it fixes the hesitation problem, well it definitely helped compare to way it was before. I am thinking that cat is pretty plugged up preventing good flow. Soon will have new cat and see.
  17. Fixed the secondary problem by going mechanical. youtu.be/pRtPH4A6JF4
  18. I put finger on port from carb and revved and felt no vacuum at all. Got car back from local shop today, wanted someone to look at it. Apparently both head gaskets are blown and the cat is clogged. So have to figure out what to do now. Would love ej swap but that's spendy. Guess I will do mechanical conversion of the hitachi and replace cat. Then change head gaskets eventually, and timing belt at same time.
  19. Well the gas starts spraying about 3000 rpm or so to allow the transfer to secondary I believe. So problem is not having any vacuum from port in carb that secondary attaches to.
  20. I plan on replacing the belts anyway. Eventually going to replace everything to keep silver going for long time. Yeah I am going to rent a compression tester from local auto parts place this week sometime.
  21. I brought car to a place that is highly recommended by some local Subaru fans. Told them what I have observed and they said they will check it out. Hopefully they can tell me what needs to be done or fix cheap.
  22. I think I might have figured out the problem. Well maybe. I had air cleaner assembly off, checking vacuum again and when it was idling I revved engine to make sure fuel was going in, at below 3000 rpm fuel was squirting in primary no problem but no fuel at all in secondary. Checked vacuum diaphragm and there was no vacuum going to it, I manually moved the secondary and it revved no problems. So problem seems to be no vacuum to secondary diaphragm, now how to fix that I don't know.
