ndu
Location
Toronto, Canada
ndu's Achievements
Member (2/11)
10
My theory is correct! I went to the Subaru dealer and asked them to test my rad cap to see if it can hold pressure. They were nice enough to do it for free. Sure enough, the cap was not working properly. So I got a new one from Canadian Tire for $10 and the cooling system is working normal now. Also my fan problem is also fixed---previously it was on all the time when engine is at normalo temperature. It feels good if your theory turns out to be true.
I drove a while today and checked the overflow tank and I do not see any bubles.....I think I will try the rad cap replacement first. Any ideas how much it will cost? any after market ones? Other observation is that my after driving for a while, my cooling fan will be always on ---- after I stop the car and kept the engine idle, the fan will keep on going -- I waited a few minutes and the fan will not stop. I think my car is experiencing a very mild overheating because the coolant at the top of the engine (where the temperature sensor located) may have been pushed out of the system so the sensor sees a slight higher temperature than the actual coolant temperature (because not enough coolant near by to take away the heat) therefore it will trigger the fan--but the temperature gauge will still roughly in the middle position--a plausible theory? Thanks for all replied.
Ya, check the simple things like spark plug wires first....It happened to me before....do not run car with misfire for long, it may damage your catalyst converter....
I kept my coolant level in the over flow tank between "LOW" and "HIGH" (actually close to LOW mark). After some mixed mode driving including some highway, the coolant level in the overflow tank will allmost full to nearly overflow. I think there may be a problem here. After I shutoff the engine, I can see in motion the coolant very quicky being sucked back to the radiator. I do not know if this is normal to Legacy 93....because this is still winter in Toronto. My car did not show any overheating (temperature guage allways points to the middle) I am concerned that so much coolant has been pushed out of the engine and radiator....Is this possibly due to a bad head gasket? Doesn't look like it because I am not comsuming coolant and I do not smell any coolant. Possibly a bad radiator cap? It looks and feels normal. Can somebody advise? I know there is the possibiity of gas pockets in the system so when I fill the system, I was careful and opened the air bleeder.... The Engine runs normal otherwise. Thanks
Wkoepp and others: Thanks for your reply. I decided to check the "simple things" first. Sure enough, one of the spark plug wire is lose from the spark plug possiblly got lose during my work. So I have been running the car with some misfires. The shake is because the misfire. I have made the connectiong good and now the car is running silky smooth. I also changes the water pump, t-stat, front oil seals in addition to the timing belt. Since it is my first time working on Subaru so it is a learning experience for me. I am glad I did it. I am sure for the next Subaru, It will be much easier.
I have just took off the cam sprocket covers (two on each side and checked the timing marks, they are both accurately positioned. I was very careful when I installed them, counting the tooth in between marks. So I do not think timing is the problem. I took the car on the high way, at around 100km with RPM 2100-2200, I would feel some kind of shake or vibaration, but as soon as I push the gas and the RPM increases, it feels OK again. The car otherwise drives OK. Any thoughts?
I have just replaced my timing belt, water pump and oil seals. It went OK and I was able to start the car the first try. But the car feels some what differently now. For one thing, the car shakes noticeably now at idle (even at P or N). It almost feels like the idle speed is low. But I measure the idle speed and it was 700 RPM which I think is OK. I also measured the vacuum and it is normal and stable. Also, the car feels little sluggish than before. At high speed (4th gear-around 2000RPM) the car also shakes. But if the RPM is high, the car feels OK. When I install my timing belt, I was careful not miss the mark and I think I installed correctly. Any other reason that can cause this? Any other way to check the timing belt (other than taking it apart again?) 93 Legacy 2.2L
I am on my way to replace my water pump. everything wet well...... I took the cam sprocket (close to the car battery) off. Before I took it off, I did not put the mark on the sprocket to lineup with the mark on the timing belt cover, now, I do not rember exactly the position the sprocket should align with the cam shaft. Looking at the back of the sprocket, I see a small cylindrical protrusion, I think I should linup (slide it into) the notch on the cam shaft, is this correct? also, I kind of expecting a pin (just like the one on the crankshat, but I do not see one. I do not know if I lost it or not....can some let me know? thanks. My car is 93 Legacy 2.2 engine...
After a lot of effort and bad language, I eventually got it off without damaging the timing cover....I used a lot of penetrating oil and let it sit overnight (what choices do I have?). I tried to remove it several times and stopped because of exhaustion. I think the way to do it is to use a screw driver work on both side of the pulley alternately, each time you can not use too much force otherwise you are going to damage the cover. This is a lengthy process and I think what a stupid design is this from Subaru. It is apparent that Subaru Engineers did not think about maintainability issues when they did their pulley design. Sure, if engine is fairly new, it should not be a big problem, But look at my engine of 12 years old, it is obvious the pulley was never been pulled before. The pulley was stuck very tight. after I got it off, I found there was some gunk cementing it to the shaft. The pulley was designed such that there is no easy way to use a puller without potentially damaging it (there are no holes with thread, the rim is so thin you can easily damage it)! What a stupid design. I did the same job for my Toyota and their pulley design was much better with tow pulleys (one for alternator, water pump and the other one for power steering and A/C) bolted together by 4 bolts. You remove those 4 bolts and you have threads to use pulley pullers-It is none issue at all! I am a engineer responsible for maintainability issues for the system we provide. There are requirements (the term for this is called MTTF "mean time to repair") for those kind of things. Subaru engineers did not think about those things carefully or may be they only thought about newer cars! The repair manual did not help much either! The Haynes manual I have show that the car they took apart are almost brand new! The point is, little consideration when they design the car can make many peoples life much easier! For me, I wasted so much time for almost nothing! also, simple things like these Subaru can not get it right, I am not sure they can get other things right either. I worked on Toyota a lot and I know because of the space limitations, it is not always easy to work on them, but after a while, you realized there is always enough room and there are a lot small things make your repair life easier. It is obvious Toyota engineers thought about them in some detail and I always appreciated it after a while. OK, enough complaints, I guess I have to run off my steam......I guess my next step is to replace the water pump. I have a question, do I need to remove the cam sprocket and cover behind it? Also, since I am this far, I also think about replacing all the front oil seals (even though there is no oil leak now). But my bad experience with the pulley make me think twice.....can somebody share their process of getting them out? I read some posts suggesting drill a holes and drive in a screw, but I do not think I have enough room for a electrical drill there...also can you get the seals out by using a screw drive with radiator on? the space seem to me a concern.... But first, I need to take a rest. I am still having muscle pains. I guess my first working experience with Subaru is not particularly good...I hope the car will treat me well after I am done......The timing belt seems very worn with cracks and yellow dusts, I think it the the original belt.....The car is no good chape otherwise. I am really, really disappointed with Subaru on this one! Sorry for a stupid question, what is PB Blaster?
no, nothing really happened at the front before other than I have to replace the water pump.... I used two screw drivers on either side of the pulley and try to work it lose but it did not work so far...there must be a better way than this....? my pulley seems realy tight and I am really afraid of damaging the cover.... any suggestions? any body used puller before. I have seen some boday saying pullers damaged their pulleys....
