BlueTrain
Everything posted by BlueTrain
howdy. well, i'm trying to help my sister replace the driver side mirror on her 07 Outback. However, i can only fine a replacement made by Kool Vue, but it says its for 2000-04 models. I can't seem to locate any made for Outbacks after the 04 model. Any ideas of places online i might be able to find the mirror for the 07, or are they the same as the earlier models? Thanks...
Mystery noise: any takers?
BlueTrain replied to CzarMohab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
my loyale's done this forever. don't think you have anything to worry about. -
Fuel Pump Failing..Not sure??
BlueTrain replied to Petersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
92 wagon -
i recently had a similar problem with my loyale. thought it was fuel related because it was hard to start and when moving from a stop, it would sputter then "catch" and would move along just fine. seemed to be fuel starved. WOT and climbing hills did fine. well, turned out to be my coil. intermittent-no spark issue. -
well, swapped in a new coil and coil wire, and problem(s) be gone.
went through the process, and no codes.. temperature has no bearing on the condition.. just a condition thats progressed from a slight hesitation, to almost stalling from a stop, to now having difficulty starting w/o giving it gas...
well, not really... so, my 92 Loyale has been acting up lately. It all started about 2 weeks ago when i would feel a slight hesitation while driving. then it progressed into where it would sputter and almost stall when starting from a complete stop. ex. car in 1st, let out clutch, give it gas, but nothing but a slight sputter..press clutch down, feather the gas pedal, and suddenly the engine roars to life. now, it is having a hard time even starting at all, unless i feather the gas pedal while turning the key. if i press the gas a few times while turning the key, it will start maybe 50% of the time. it won't start at all by just turning the key. pulled the plugs, all fine and have about 12,000 miles on them. wires have about 25,000 miles on them, as does the cap and rotor. fuel pump cycles on when i turn the key, so it's working. i'm leaning towards a failing coil as if i mess with the wire going from coil to rotor, i can get it to start, but again, need to give it gas to get it to start. also, this "sputtering, stalling, missing" condition only appears to be happening at low rpms(under 2000) or from a stop. haven't had it out on the highway to check out performance, but it seems to have enough power to climb hills around here without a problem. i don't know..anybody care to chime in?? thanks in advance folks...
91 loyale is it worth $2500.00?
BlueTrain replied to mattri's topic in Old Gen.: 80's GL/DL/XT/Loyales...
exactly. for that money, you should be able to find a legacy in good shape. that's way too much for a loyale, even with the "rocky mountain markup". i bought mine for 1200-ish 5 years ago with 145,000 or so on her. -
Father's wrecked 1992 Subaru Loyale
BlueTrain replied to suba258k's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ummmm......What? :-\ -
baja exterior plastic
BlueTrain replied to street legal go-kart's topic in Old Gen.: 80's GL/DL/XT/Loyales...
nice attitude... -
Ad in local paper, '92 Loyale -Opinions?
BlueTrain replied to thelynns's topic in Old Gen.: 80's GL/DL/XT/Loyales...
er...loyale's are fine rigs, just not with the auto tranny. oh, and they do in fact have the adjustable lumbar support (if that really matters). -
funny, i thought of a few of your trashwagons when i first viewed the ad.
Found this ad today. Anybody need a "freak wagon" http://montana.craigslist.org/car/589347984.html
the "wonderful japanese engineering" you are so wrongly ripping on has always gotten me through more snow than i probably should have been driving in. Sorry you seem to have so many problems with your ride.
Need Suggestion for a EA82 Cup Holder?
BlueTrain replied to cole098's topic in Old Gen.: 80's GL/DL/XT/Loyales...
well, i took a piece of wood and gorillaglued it to the plastic next to the ebrake. then i took one of those clip on to the door between window and door cupholders and cut off the part that holds it on to the door, leaving just the part that holds the cup. then i just placed it on the wood that i glued on, and drilled a screw through the bottom of the plastic cupholder into the wood. works perfect. -
heh.. sounds like fun.... actually, missoula doesnt usually get this cold. we have a couple bouts of arctic air fun every winter, but it's normally pretty mild. nothing like my days of living back in the upper peninsula of michigan. now that was winter.
Replace your PCV valve!
BlueTrain replied to GJTaranto's topic in Old Gen.: 80's GL/DL/XT/Loyales...
awwww.. that wasn't harsh at all. just a bit of mild smartassery. -
winterbound by choice, my friend. hard to snowboard and mountainbike, without, well mountains. i love snow and cold weather. my loyale on the other hand..... takes her a little time to wake up on these cold mornings.
Well, it was a balmy -14f this morning when going to work. My Loyale had all of it's cold weather quirks on display. Let's see. Gas pedal sticks to the floor, clutch sticks, fuel pump becomes very loud, tailgate latch malfunction, speedo cable makes the loud whirring noise for 20 sec. . I was just talking with one of my co-workers who also has a 92 loyale, and we were comparing these cold weather quirks. So, anybody else have rigs with these cold weather oddities?
well, locals out here in montana have the cargo boxes. work great for those long trips to the montains, keeping the road grime off freshly tuned boards/skis.
