screwdriver
  • Location
    Rocky Top, TN
  • Vehicles
    1997 Outback
screwdriver's Achievements
Newbie
Newbie (1/11)
0
  1. Thanks for all the great info and tips. I'll be trying these suggestions out as time and money allows. I'll post the results when I can
  2. These are my codes 1) PO303 Cyl 3 misfire 2) PO500 Veh Speed Sensor A Malfunction 3) P1507 Manf Cntrl Veh. Spd. Idle speed control aux. inputs 4) P1540 Manf Cntrl Veh. Spd. Idle speed control aux. inputs
  3. Thanks. I'll go down this list. The car runs perfect when cold, then when warm/hot it starts this stuttering at 4300rpm. 1) PO303 Cyl 3 misfire 2) PO500 Veh Speed Sensor A Malfunction 3) P1507 Manf Cntrl Veh. Spd. Idle speed control aux. inputs 4) P1540 Manf Cntrl Veh. Spd. Idle speed control aux. inputs
  4. a lot of codes. 1) PO303 Cyl 3 misfire 2) PO500 Veh Speed Sensor A Malfunction 3) P1507 Manf Cntrl Veh. Spd. Idle speed control aux. inputs 4) P1540 Manf Cntrl Veh. Spd. Idle speed control aux. inputs
  5. Hello, I hope someone can help me with this. 1997 Outback. 4 cylinder. 5 spd. 260,000 miles. When you start out cold it revs normal but after warm up it starts shutting off at about 4300 rpm. It's not dying just cutting out like it's starving for fuel. When you back off the throttle and get below the 4300 rpm it's fine again. May be electrical of course. Any input on this would be appreciated speedometer stopped working at 256k 1) PO303 Cyl 3 misfire 2) PO500 Veh Speed Sensor A Malfunction 3) P1507 Manf Cntrl Veh. Spd. Idle speed control aux. inputs 4) P1540 Manf Cntrl Veh. Spd. Idle speed control aux. inputs
  6. Hello, I hope someone can help me with this. 1997 Outback. 4 cylinder. 5 spd. 260,000 miles. When you start out cold it revs normal but after warm up it starts shutting off at about 4300 rpm. It's not dying just cutting out like it's starving for fuel. May be electrical of course. Any input on this would be appreciated
