XHighOctanex last won the day on August 31 2017
XHighOctanex had the most liked content!
About XHighOctanex
- Birthday 08/01/1997
Gender
Male
Location
Vacaville California
Referral
Google for lifts for the loyale
Biography
Really into my cars and using them to adventure
Vehicles
1992 Subaru Loyale(Trailbaru), 63 Fairlane
Recent Profile Visitors
6258 profile views
XHighOctanex's Achievements
Eat, Live, Breath Subaru (5/11)
17
My build "Trailbaru"
XHighOctanex replied to XHighOctanex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
last post ended up blank? Here's the link -
Got my keyless entry and remote start wired up and done also got some side markers finally! -
I cut out the stock plug for the loyale lights and ran the plugs for the duals. Took me a minute to remember they're a negative trigger setup but everything is wired in as if it was a DL now
I fixed them. Idk what the hell I did that fixer it but i cut open my harness and went through that side and now they're fine. So must have had a bad crimp or something idk
And I popped the cover and they looked fine but I'll see if any feel loose
92 loyale
Hey guys, so long story short my headlights decided to tweak out on me. Passenger low beam just doesn't work, fuses good, light itself good (I seitch Ed sides and stayed the same). So I went deeper, since I did the conversion to dl lights I thought maybe I fudged up so I undid my electrical tape and checked all my wiring and it was fine no cut wires or anything, so I cut the harness up a little and got the crimps out of the way and still nothing, now I haven't tested for whether I'm missing power or ground but I'm guessing ground, here's why, when I turn on my high beams BOTH passenger lights turn on and then the driver HIGH BEAM but them the driver LOW BEAM that previously worked shuts off. So it's like the combination switch blew out a connection for the low beam ground on the passenger side or something? Thanks everyone
Only car I've had an alternator go out on was my loyale lol and that was before I got it, drove it home on just a battery 100 miles. Ran out of juice as I got into town and swapped to another I brought (and this was at night so had the headlights on lol) and I'll definitely do the orings then probably the same time I do the clutch.
I'm gonna do a timing belt component kit, plugs, wires, fuel filter, already changed the oil and ran some marvel mystery oil with it which quieted the lifters up a lot, I'm very strict with oil changes on my cars we've put a few engines in subarus at the shops in roos run out of oil lol and are the alternators common on the 2.2s?
Hey guys, for anyone that doesn't venture into the loyale section I own a 92 loyale wagon that's lifted and all that jazz named Trailbaru. I've been dailying an 04 golf for about a year and I don't enjoy it much anymore. I picked up a pretty decent condition 96 legacy outback 5 speed, 2.2. Now I work on a Lot of subarus so I know most of the issues to look for (leaky head gaskets, check timing belt service records, how much oil it burns, etc etc) This car has 233k miles, which is above what I wanted but I can track down a much lower mileage 2.2 pretty easy. Trans shifts good, engine sounds good (gets a lifter tick on the passenger side from time to time but it's real quiet) this car has the dryest subaru engine I've EVER seen. The only oil underneath the car is from the oil filler neck that just barely leaks. Other than that it's dry as a bone under that car. Kicker with this car is it needs a clutch, which I'll do next week when I get back from vacation. Basically I want to know if there is anything specific to look out for on these particular roos that aren't as prevalent in the others? Sorry for the long post guys.
Ea82 steering rack options
Look for tears in the rack boots. They're just dust covers so make sure there is NO fluid leaking out. It's nice if the inner rods are stiff but off a parts car I doubt it. Floppy will still be fine. Really just make sure nothing leaks. -
I've had my permatorque up to 260 a couple and 240 cruising a few more times and it still runs like a champ, no coolant loss whatsoever.
- 23 replies
