Serpentine Belt pulleys
srs_49 replied to netman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI replaced both of mine on an '02 H6 back in the fall. Bought two identical pulleys from the dealer, and put one on the tensioner and one on the front of the engine itself. Only one of the pulleys was bad, but I replaced them both. This was at 104K miles or therebouts.
1998 Outback Battery Drain when Parked
srs_49 replied to jeffx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a similar problem with a '74 Datsun 260-Z. It had an ammeter as part of the instrument cluster and, when the car was off, it was showing a bit of a discharge. One of the diodes in the alternator was shorted, which was allowing the battery to drain. The other diodes (it was a 6 diode, 3-phase circuit, if I remember correctly) were OK and would charge up the battery once the engine started.
what do you get for gas mileage?
srs_49 replied to mellow65's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2002 OBW, H6, no mods. Never got anything over 25 mpg, even on the highway keeping it to 65 mph. Overall, averaging around 23 mpg.
Rotor Replacement?
srs_49 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAre you talking about a clear coating - almost like a shellac or hard petroleum jelly? I just put some rotors from Beck Arnley on my BMW and they were coated with some material like I described. I assume it's put on as an anti-corrosion protection.
Rotor Replacement?
srs_49 replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNot to hijack the thread, but I had a '73 Fiat 128-SL that I managed to keep running for 128,000 or so miles. Yeah, it was pretty crappy in ways, but was still loads of fun to drive. Engine was great. Clutch cable would always break in the middle of downtown rush hours (got it home both times without using the clutch). Had to replace front wheel bearings every 35,000 miles or so. Also, would go like there was no tomorrow in snow, with those skinny 13 inch wheels and tires.
Trailer Wiring Harness Question -- Splicing?
srs_49 replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSkip - Are you sure they're SCR's and not just plain diodes? If the latter, then could just wire a diode in series with the spliced connection from the turn signal wire.
105K Mile Service on a 2002 OBW H6
srs_49 replied to srs_49's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
- 2003 Outback H6 Timing Chain Tensioners Question
srs_49 replied to dbullen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI agree with Skip. We liked the improved performance of the H6 compared to the H4 and were willing to pay the penalty in reduced gas mileage. BTW, we have over 106,000 miles on our '02 OBW H6 and are still very pleased with it overall.- Knock sensor wire sheilding repair. EJ22.
srs_49 replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't know for sure, but my guess would be that it does. As I understand it, one (the only???) of the functions of the knock sensor is to prevent engine damage cause by pre-ignition/detonation that could be brought on by running a lower octane gas than is recommended or by somehow having the timing advanced too much. Unless there is some other mechanism for retarding the spark timing when the engine is cold, these conditions could be present when the engine is cold (if a lower octane gas was used, for instance).- 2003 Outback H6 Timing Chain Tensioners Question
srs_49 replied to dbullen's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWe have a 2002 H6, LLBean Edition. I don't think we've ever gotten more then 25 mpg on the road. May have eeked out 26 once - don't have mileage records with me to be sure.- Knock sensor wire sheilding repair. EJ22.
srs_49 replied to GeneralDisorder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI would not be so quick to discount the lack of the shield on part of the cabling. How much noise/interference is coupled onto a wire (or set of wires) is highly dependent on the frequency of the noise source. In general, the higher the frequency, the smaller the opening in the shield that is needed to allow coupling. Given the relatively low signal level out of the sensor, it would not take a lot of coupled noise to cause a problem. The fact that these wires were shielded originally means that the engineers at Subaru determined that such shielding was necessary. Due to the cost difference between shielded and unshielded wires (and thair associated connectors), they probably would not have specified a shielded cable if an unshielded one would do. I'm not saying the problem isn't the knock sensor itself. Just be aware that the cabling may be part of the problem too.- Used legacy, should I buy extended warranty?
srs_49 replied to ron2368's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI am not a fan of extended warranties, for the simple reason that they are big money makers for the issuers. If the dealer/manufacturer/insurance co. is making upwards of 50% or more on these policies, doesn't that tell you something? That said, if you really want one read the contract first, before handing over any money or signing any paperwork. Look closely at what items are excluded and also what the "deductible" (your out-of-pocket expense) is for any given repair. Also, ask what happens if you have to bring the car back in to fix the same problem again in a short time - do you have to pay another deductible? Good luck!- Wheel bearing question
srs_49 replied to Sirlono's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used to have to replace the front wheel bearings on my '73 Fiat about every 35,000 miles. They were pressed into the hub. I would take everything apart, take the hubs and the new bearings down to a machine shop and they would press the old ones out and press the new ones in for like $20 a hub. Of course that was 30 years ago so price would probably be higher now;). Point is, don't shy away from trying this just because you don't have a press.- Brake booster not working when cold outside?
srs_49 replied to ericem's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI had a similar problem with our '02 OBW. It went on for 2 years(?) or so. I did what Nipper suggested, and cleaned out the check valve in the booster vacuum hose with parts cleaner (actually, I may have used carb cleaner, not sure). It's been fine ever since. Theory is that a little moisture in the line would freeze the check valve and prevent the vacuum from reaching the brake booster. Cleaning out the hose/valve removed the moisture. I would try the simplest/cheapest fix first. For more details, search this thread for "brakes not working when cold" or some similar terms.- Tire Recommendations
srs_49 replied to usaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou might want to read through this thread- http://www.ultimatesubaru.org/forum/showthread.php?t=81842 BTW, I've had the Goodyear Assurance Triple Treds on for 40,000 miles now and have been happy with them. - 2003 Outback H6 Timing Chain Tensioners Question
srs_49
