Curtbed
  • Location
    Vancouver wa
  • Referral
    Internet
  • Biography
    30 year old trying to get to work but car doesn't run
  • Vehicles
    1984 subaru dl
Curtbed's Achievements
Newbie
Newbie (1/11)
  1. Has a new coil and fuel pump was having trouble with key on for the fuel pump power but I wired around it with some relays it seems to run fine until it's warmed up now can cruise around for a bit then get up to about 30 mph and starts bucking and will shudder out and die then hard to restart
  2. Thank you first time owning a subaru seems foreign to me
  3. Hi I have a 1984 dl 4 door sedan 1.6l ea 71 manual trans When I bought the car it ran great for 2 trips to work it then began bucking and kicking while accelerating and cutting out completely then would be hard to restart. I gave it a tune up cap rotor plugs air cleaner. Did not fix it changed both fuel filters and threw a fuel pump at it just for the hell of it. Still the same I've attempted to read the codes it had a code 13 one long blink 3 short at first but has changed to a code 33 3 long blinks 3 fast. I'm not sure where to go now I believe I found the fuel pump relay under the passenger seat I've swapped them around didn't change anything it will start and idle for some time then will cutt off sudenly.
  4. Hi I have a 1984 dl 4 door sedan 1.6l ea 71 manual trans When I bought the car it ran great for 2 trips to work it then began bucking and kicking while accelerating and cutting out completely then would be hard to restart. I gave it a tune up cap rotor plugs air cleaner. Did not fix it changed both fuel filters and threw a fuel pump at it just for the hell of it. Still the same I've attempted to read the codes it had a code 13 one long blink 3 short at first but has changed to a code 33 3 long blinks 3 fast. I'm not sure where to go now I believe I found the fuel pump relay under the passenger seat I've swapped them around didn't change anything it will start and idle for some time then will cutt off sudenly.
