RolyPoly
RolyPoly last won the day on January 18 2017
RolyPoly had the most liked content!
About RolyPoly
- Birthday 10/28/1999
Gender
Male
Location
Aberdeen, Washington
Referral
I found this site multiple times while looking for parts/modifications for my 91 subaru loyale
Biography
I recently rolled my 91 subaru loyale. I have found another to buy and was planning on doing modifications to the new one and the new one does not run so will probably be asking questions/needing help.
Vehicles
1991 Subaru Loyale
RolyPoly's Achievements
Member (2/11)
3
I have another issue with the car. I replaced the two belts on the front main pulleys and made sure they were tight. Then an aftermarket oil pressure gauge line was rubbing on them and it got oil all over them. I have the alternator tightened as tight as it will go and the belts are still loose. Do I need to replace them again? They were brand new
Need parts for 1992 Loyale
RolyPoly replied to SnowLeopard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am in Aberdeen also haha. Which one is it? I only know of one that has 1 or two and thats emery's -
I have a wrecked 1991 Subaru Loyale. It ran and drove after the wreck but it doesnt run now due too me taking off fuel pump throttle body and tune up supplies. It might have those parts, I am thinking about parting out the car, I am just needing to know prices on everything before I part it. I dont exactly know what those sensors are and where they are but I could look and try to find. I am located in western washington -
Thank you all for the help
The car is fixed thank you though. I had the fuel lines switched.
The fuel lines to the throttle body were switched ahhaha. The guy i bought it from said he had it on the right way so i assumed he was correct because he was a mechanic ffor 65 years. I switched the lines over and it sttarts right upp The engine doesnt have a super loud tick and it runs nice. I just need to get the brake on the right side unstuck, the wheel rolls but only if im giving it gas it wont roll down a slope by itselff
both of the fuel lines are pressurized when i pulled them off. They sprayed me all over. The lines get gas all the way to the throttle body. Once the fuel gets to the throttle body I am not sure what happens but somehow its not letting fuel somewhere in the throttle body?
I put everything completely together and it still didnt start. i replaced the throttle body, fuel filter, fuel pump, and the computer. Still is doing the same thing.
I replaced the fuel pump did a full tune up and still the same issue do you think it could be out of time? It seems to want to start
The car does not run for more than 10 seconds. I would say maybe 2-4 seconds.
I will try tapping the fuel pump with something to see if it makes a difference.
I will try this today. I will report back after i do that.
I could tomorrow the car is still sitting at the owner place. I am hopefully getting towed to my place tomorrow. I have been reading around and saw that another person had a similar issue and he replaced the fuel pump and he said it ran fine afterwards. Do you think that could be the problem?
also the automatic Subaru had an issue to where it wouldntt go over 25 MPH, it eventually stopped starting the owner told me. Thats when he switched over the throttle body and it didnt ffix the automatic subaru problem so he switched the throttle body back and the manual Subaru (the one i bought) didnt run affter the switch. It ran before the owner switched the throttle bodies
I checked the fuel lines and they were put in the correct order. I have a donor car that I had rolled. I put the throttle body off the rolled one on my new Subaru exactly how it came offf.
