Posts posted by YnotDIY
9 hours ago, DaveT said:
Take off the manifold. Clean the faces. Set it in place, try a feeler gauge to see if you can pick up on how flat the faces are lining up to each other. You might need to use a set of gaskets while doing this, depending on clearances, etc. Maybe lightly installing a couple of the bolts
ah! of course. thanks dave!
2 hours ago, 88SubGL said:
Buying your gaskets directly from Subaru? I have heard of problems with aftermarket intake gaskets.
yes they are subaru gaskets. that's the only way to go.
I'm pretty sure my intake needs machining.
24 minutes ago, DaveT said:
They are not supposed to be into the coolant. Even if one [of the 2 near the coolant port] was drilled too deep, it would intersect a head bolt. The outermost one - on each end, those might eventually hit a coolant passage if you were to drill deep enough, but they do not connect in a stock head. The head bolts are not really sealed off from the crank case, but the head bolt and washer make it not really open either.
In a stock head, if there is coolant in the space around an intake bolt, it is coming from a failing intake gasket, or crack or warp in the manifold.
ah thanks dave. I've struggled with keeping intake gaskets from leaking on this engine. I've gone through 3 sets in the last year alone.
They fail in the same place every time, drivers side intake bolt closest to the front of the engine.
Totally possible the intake is warped.
does anyone know which intake bolt goes into the coolant passage on an EA82? I know one of them is leaking coolant into the intake.
gonna try and throw some RTV on the bolt and see if that stops the leak.
Only thing is.....which one?
Did this repair today. Worked like a charm.
3 hours ago, el_freddo said:
You probably need a new sender unit.
Cheers
Bennie
Ah run high? I know very little about electrical. Got a new sender unit stil no luck. Let us know if ya figure it out!
Haha yeah I know the procedure. It’s crazy though. I was using a 7lb hammer and a 2x4 and couldn’t get the thing off.
guess I’ll smash harder and see what happens. I have another as well. I’ll take that apart and see if the outer joint removes easier on that one.
maybe the one I have is just stuck.
It seems for the life of me I cannot get the outer joint off this axle! Inner joint, no problem. A couple of rings and it came off.
I read you just have to clamp the axle and "smash" the outer joint until it pops over the c retaining ring. Welp. I've been smashing and smashing but this thing will not budge.
What's the deal? smash harder?
mine has been out since I bought the car. I have a spare gauge cluster, but I'm hesitant to throw it in. If it's a short somewhere i dont want this fresh one to get toasted.
@FerGloyale the painted mirrors are sick. I'll definitely be painting mine.
@IFlyS5 bed liner bottom? -
Hey Ya'll I've been looking for pictures of people who have Two Tone painted their Old Gens and found a thread from...2006.
For those who have been around here, ya it was post photo bucket collapse. All the photos were gone besides Miles Fox's. It was not a
kind of thread.
So I'm here to start a new one or be pointed to an existing one!
Post your Two Tone photos here!
I'm painting mine in the next two weeks. I'll post when it's all set.
Cheers y'all!
Sorry Sorry NVM! just asked this question before research. RockAuto has them.
On 8/15/2019 at 10:00 PM, DaveT said:
Clean, re grease, reboot OEM axles. From everything I've seen on here, the aftermarket axles are junk. A long while back, I remember mention of one brand some had good luck with, but I never tried them. I've been rebooting them since 1988.
Where to find new boots for OEM axles
Hey hey -
Swapping the heads on a forester right now that had a couple belt valves from breaking a timing belt.
my dog, a doof, stepped on the timing covers while they were off and broke them!
I know people run open covers on the EA82, I do that myself, but I’m wondering if anyone goes without the covers on the EJ25.
Gotta finish the job today. What do y’all say? Okay to run this forester w/o timing covers?
@DaveT @sparkyboy @el_freddo @czny
Swapped the intake gaskets with OEM.
after taking the aftermarket off (which were totally ripped on both sides!) and looking into the engine, which was totally stained with coolant that was my issue!
no more coolant loss and it’s running great. Looks like the head gaskets are safe for now!
thanks for the help.
3
when doing intake manifold gaskets with OEM gaskets is it necessary to coat them with coolant resistant goop?
I've done this (as was suggested to me) with non OEM gaskets, but was curious what procedures ya'll use.Any Tips and Tricks?
@DaveT @sparkyboy @el_freddo @czny -
@DaveT I remember you also saying to check the coolant hoses and that there are 7? of them.... Obviously I know of the common 4. Inlet and outlet hoses for rad and heater core....where are the others? One tiny one off the water pump?
On 1/25/2019 at 1:03 PM, sparkyboy said:
But that coolant dosen't just disappear, if you aren't burning it in the exhaust (white smoke on start up?) then it's going into the oil and those bearings will be hating life.
It's hard to tell because it's been so hecking cold in Chicago (-20), but it believe I'm getting a lot of white smoke on start up. It seems to go away after a couple of minutes and I'm definitely smelling a sweet smell to the exhaust. Could that be some failed intake gaskets? I did change them when I got the car because they were leaking. I think I used some chepo gaskets.
On 1/25/2019 at 10:28 PM, DaveT said:I've only seen coolant in the oil once. Very blown headgaskets. Not the early initial stages when the coolant just keeps disappearing, or small bubbles in the recovery tank. I've been down this road a number of times.
My experience with the coolant level you describe - it may have been drawn down by a slow leak anywhere - to the outside of the block, down the intake. But the level low in the radiator + over normal temperature [does not have to get into or even near the red] has always lead to failed head gaskets, it might be 6 days, might be 6 months. I never had one consuming coolant down the intake at a high enough rate to show smoke [steam] in the exhaust.
@DaveT When I first got on here i remember you saying to use good intake gaksets because the non-OEM ones are bogus. Maybe this is what's causing my problem and not Head Gaskets....my engine temps seem to be normal to me....what do ya think?
Hey Ya'll
Just checked my coolant levels last night and the reservoir tank was empty. Checked the rad and it was low as well. I'm fearing the worst...head gaskets starting to fail...got some sludge on the oil cap and a bit on the dip stick....I've also heard it's possible to get these symptoms with a failing intake gasket...my hope (of course) are that the intake gaskets are failing to keep the coolant passage closed.
In everyone's experience what do you think?
I haven't noticed any major overheating, but the bit of sludge on the dip stick really has me worried.
Is it possible to get these symptoms with a failing intake gasket?
Thanks! -
Great ride! Where did you get those Center Caps?
On 12/30/2018 at 2:37 AM, el_freddo said:
Plus the Tercel, 505(?) and the Magna of the same era - very close back in the day but easily distinguishable apart today!
I still Iove the L series and it’s shape. I also love the fact that I can choose what computers to put in it. Currently it has one for the EJ. It’ll stay this way too.
Cheers
Bennie
Bennie -
Do you have an EJ ECU and an EA82 engine? I didn't realize they were compatible like that. -
awesome, thanks @GeneralDisorder. Got both LH and RH today. Will be swapping them tomorrow.
I'll post some pics.
So just checking but, seals that are 30x50x9 should work?
Subaru Falls On Its Face, Upon Acceleration.
Posted
following this
