wmaney
Location
Frenchville, PA
Referral
Internet
Biography
Subaru owner since 1981
Vehicles
95, 99 and 09 Legacies
Recent Profile Visitors
530 profile views
wmaney's Achievements
Member (2/11)
0
Our 2009 Legacy Special Edition with 196,000 miles has a vibration in the steering wheel/body when turning right(even slightly) at 65-75 MPH. CV boots are good. Left front wheel bearing was slightly loose, changed it. Still vibrating. Changed both front axles. Still vibrating. Tie rod ends and ball joints seem tight. Any suggestions? Could it be the u joint in steering shaft? How about the rear CV axles? Disgusted with this issue.
Yes the ignitor is in the ignition coil. Pulled the timing belt cover. Left bank cam timing is good. But right cam is one quarter turn off. This is with 50 miles on new Gates timing belt kit and Felpro blue teflon head gaskets. I replaced the right bank plastic cam sprocket with an old 2.2 steel cam sprocket. I then checked compression. All cylinders are in the 130-180 range. Good for an old motor. The question is why did it jump time? I have replaced my own Subaru cam belts since the eighties.
I have a 1999 30th Anniversary Legacy sedan, Automatic, AWD. It cranks but won't start. It shut off in the driveway and won't start again. Replaced coil, crank and cam sensors. I want to check the Ignition Control Module/Ignitor but can't find it. It is not on the middle of the fire wall like my 95 Legacy or near transmission resistor on right front strut tower. Where is the Ignitor? This is a 2.2 Phase two engine. One year only. Also weird is that is has no air flow sensor in the intake pipes.
