Location
Hoquiam
Referral
google
Biography
I want to lift my subi, and want to do it proper
Vehicles
92 loyale
tysons92loyale's Achievements
Member (2/11)
2
tysons92loyale started following AKIRA
I'm trying to overhaul my engine, but I can't get the block to split. I've taken every bolt or, got the pistona out. I'm not sure of any tricks. Any suggestions?
Fuel Pump goes on with headlights
tysons92loyale replied to jread's topic in Old Gen.: 80's GL/DL/XT/Loyales...
there's a short somewhere, you need to go through what you did and look very closely. using a volt meter with the circuits will help isolate the situation -
Need parts for 1992 Loyale
tysons92loyale replied to SnowLeopard's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Where at in western washington are you? Im in aberdeen and there is a wrecking yard up the street from me and they have a few Loyales there. -
https://www.autowrecking.com I'm not sure where your located but this is a chain company -
Trouble Turning off 1978 Brat Fuel Pump
tysons92loyale replied to 2337BRAT's topic in Historic Subaru Forum: 50's thru 70's
disconnect the battery- 3 replies
- Fuel Filter
- Fuel Pump
(and 1 more)
Tagged with:
Dave T. All data is a program used in my shop, its like a online chiltons. The engine is a 2.5l and there is 160,000 miles. the timing belt was replaced at 75,000. I put on both new tensioners, the toothed idler gear and tensioner. Plus water pump and gasket and thermostat. IDK if the heads have been replaced. My sister just bought the car. I didn't work the air out before driving it. 1 Lucky Texan. I remembered to plug in the fans. I remember to pull the pin and i put a new thermostat in. at first I thought i put the new thermostat in backwards but i didn't. I didnt see any coolant from the TB case. db 213. It is an automatic. On a side note, if the waterpump was faulty, is the company responsible for the bill if I need to get new valves and heads? Once i get my kids down for a nap I' going to go pull the TB case.
I just put a new timing belt, water pump, and pulley on. I drove about a mile and then the subi started getting real hot. Before it red lined I heard a very small click and the subi died. The timing belt is came off and is now sticking out of the timing case. I did everything to a T according to alldata. Can someone point me in the direction of where to start looking on what went wrong? Thank you very much
I would look at a junk yard, and bring your dmm to check the ohms before you buy it
