Do It Sidewayz
Everything posted by Do It Sidewayz
WJM is at it again...N/A EA82
Do It Sidewayz replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i think the main hold up in this plan will be the heads. those things don't flow well at all. they are bareable with a turbo set-up as the turbo just crams air in there anwyays. you will need to look into springs. I've had these things floating at 7 K. -
Show me your Justy Projects!
Do It Sidewayz replied to djkindt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had mine turboed for over a year. I used a IHI turbo from the 1.8L subarus, All the other stuff was custom made. I ran about 8-10 psi, and if i had to guess. i was making 115 hp. I absolutely could not keep a clutch in the car though. I went through 2 stock clutches, and then finally got a custom double sprung pressure plate, with Kevlar disc made. The car never actually got tuned 100%, as i still had stock injectors in it, but i had a Greddy Emanage system installed in the car, which allowed me to tune both fuel and spark. Even at a crappy state of tune (i would have to guess i left 15 hp on the table). i was able to outrun my buddies Legacy Turbo which ran a JDM ej20, and also USDM WRX's. The car was a rocket till about 100 KPH, which is where it completely ran outta effective gearing. I took the car apart, to restore the rust, and continue modifying it, but i found a more practical car along the way (1988 Toyota Celica Alltrac) Heres a pictures of my justy: -
Subaru RX Type RA?
Do It Sidewayz replied to eddygordouk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
he's right.. you need Pistons, Rods, and Head Gaskets, along with some SERIOUS head work to make them flow something respectable. Pistons are going to be a grand Rods will be half that Head Gaskets will be zillions! With the amount of EJ parts that are lieing around in people shops, and the amount of parts that get thrown out, you could easily build 12 EJ's for the price of a proper EA motor. PLus you'd make the same, if not more HP -
MUST SEE RARE JUSTY CLUTCH lol
Do It Sidewayz replied to JustyPimp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
i think that's a generic picture I got a clutch like this custom made for my justy. with a 1200 LB/in pressure plate, Kevlar disc, and 12 Lb flywheel. i was also making 125 hp. -
the car i removed the EJ20 from, was a Legacy Turbo, and back in time had the ej22. No modding was needed in that swap
no you don't! my EJ20 dropped right onto the EA82T cross member. i didn't even think of touching the holes.
To the rear axles...ZERO...just swap in the new Differential. Front axles are a direct slide on the tranny, and drive in the pin. The main prop shaft, needs to be shortened around 60MM. and will generally cost you around 100 bucks.
you will have fun mounting the Top mount Intercooler in the XT engine bay, as the firewall is that much closer. it's tight in mine even, and i have the spare tire well. Use the EJ tranny...it's not that bad to get it worked out. Just need to do a tranny x-member, and shorten the main prop shaft.
well..here's the most recent. won't be many more for a while. it's down to crunch time. as i leave thursday noon for Maniwaki, Quebec.
It's alive!!!
I know you are prolly talking about me, because recently i've been bashing the EA motors, and jumped on the EJ20 bandwagon... I'm just a little frustrated after blowing up 2 basically STOCK engines after 4 rallies. We've also blow up numerous engines in the years past in our race cars. Honestly...i'd still like to build an EA to the tits...but at this time it's more cost effective for me to just go with an EJ motor. Never the less...with the fuel rails...i'm not completely certin that the cylinders all get equal flow. And i think that a "parrallel fuel rail" mod would go a long way. I did something similar on my race car last year, and it worked really well! If i remember correctly i think the stockers were like 185 ccs or something crazy like that...which actually makes sense...since those running at around 65-70 % duty cycle is somewhere around 115 HP...
Cometic discussion, thickness
i can tell you from when i did research during the summer for the EA... after talking to a number of places...most of them suggested o-ringing as a cost effective alternative. I was looking at about 200 CDN to do it...which is not gross. they also really suggested that they had both the block and the heads...so they could be resurfaced. And suggested that with perfectly flat and true mating surfaces you would be fine. Looks like really the only options are the Coppers, or the Stockers. The coppers you can order from Flat-out group....the rubber coated ones look like they might just work nicely. Personally...i think alot of the problem has to do with the way that the coolant passages are routed in the EA heads. You have hot hot coolant from the turbo dumping right into the head... We have put some thought to rerouting the coolant lines (like t-ing the heater hoses, which would have the benefit of super hot heat in the winter). Good Luck. If you do find a decent alternative..let me know...i have a friend who still wants to build the tits off a EA motor....since he keeps blowing them on the street (went through 2 in like a month) -
yeah and 220hp. these things have metal headgaskets stock???
Off to Talladega tomorrow
my advice...keep and eye on your temp gauge. when i was running rallies in the summer with a completely redone, recorred rad, which was clean...it would get up to like 3/4 temp...not nice at all. i'm also betting you run into braking problems. but have fun, and let us know if she goes bang! -
rx runs bad on 105 octane
Do It Sidewayz replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
not all race gas is leaded! I have like 40 liters of 114 Octane race fuel sitting in my garage...it's unleaded! I run this stuff in my 85 RX rally car, and it loves it!!! -
you are pretty much correct. I started on Sat night, and got frustrated/tired and wend to bed so i didn't screw anything up. Finished it up Sunday morning...All told...probably a total of like 4 Hrs sitting on the floor with the diagrams, knife, and diagonal cutters Not entirely sure it's going to be 100%...but i'll figure that out once i put it in the RX!
the old RX is completely stripped, and tonight i managed to futz around with the Pedal box, and now the Hyrdraulic Master cylinder is installed, along with Legacy Throttle cable... Tomorrow should be d-day, and the EJ20 will be dropped into place
you are close. The motor is a JDM EJ20 from a Legacy of some sort (came with the WTA intercooler) The tranny and diff are from a USDM Legacy Turbo. Wiring harness is from a USDM Legacy Turbo. All this is going into my 85 RX Rally car, because i'm sick of blowing up the EA82!
Spent just about all weekend in the garage...got a good amount done i figure. Conisdering i was working by myself most of the time. So far just in the prep stages...after dinner tonight the RX will be disected, and prepared for open heart surgery Friday night...got all these things out by myself in like 4 hrs. Then spent yesterday ripping the wiring, and stripped it right down this morning. What's needed and what's left over!!
well. i dunno about WJM.. but personally. i was running my 85 RX in P4 Performance Rallying. i was up against 2.5RS's, WRX's, Talons, etc. basically, engine management is free as long as it is "plug and play", this means that WRX guys are running anti-lag, and are tuned right out for the 32MM inlet restrictor, open exhaust, and 110 Octane Fuel. You add all that up, and a WRX is easily making 250 hp crank. I was running 7-9 PSI with no intercooler (because of the class), on 110 Octane race fuel (to fend off detonation), and just open exhaust and K&N. And i still can't/couldn't keep the things together. Overall though...i was competitive in the class, but i had to push the thing to within an inch of it's life (WOT ALL the time) for 20 kms at a time.
my thing here is.. I put 2-3 grand into an EA..i'll be making 200 or so HP...RELIABLY. I put 2-3 Grand into an EJ...i am 1. getting ALOT more for my money, as things are available and i don't have to pay for the "customness". and 2. i'm going to have 1 hell of an engine, and dam near close to 300 HP reliably. Then again...i'm also paying next to nothing for my engine swap.. Probably a fuel pump, and some other odds and ends (some injectors, with STi Ver 2 Manifold, and a stock WRX BOV).
Might be the case.. but if i can have a 115hp EA. or a 230 hp EJ20...and they last the same amount of time...i can have twice the amount of fun in the woods.
No..EJ's are for those who have blown up countless EA's. After i blew up 2 in 4 rallies, i had to think about something else...especially since i was running almost bone stock (7 psi, exhaust, and k&N) To build a reliable EA you are seriously looking at 2-3 grand. You need rods, pistons, MLS gaskets, bigger turbo, I/C, and some serious Engine Management. For me...all that crap puts me in open class. Why run an EA which might make 200 HP reliably...when i could drop in a STOCK Ej20 and make the same power and have almsot factory reliability?? Also take a look at the FACTORY SUBARU Rally prep info...here http://www.faberit.com.au/rxrally/Pics/RX_Docs/index.html They did all these engine mods (pistons, rods, cams, ECU, Turbo, and Crank)...The make like a whopping 170 hp...And they were also notorious for blowing smoke and not making it through rallies without blowing up! Nice. Alltrac I/C BTW...i've got 2 of those sitting in my garage!!
Rick... WRX does not use a 3.9 ratio in the rear. it's actually a 3.54 i believe, WRX tranny is not 1:1 center diff ratio... The front diff is 3.9, but the rear is a 3.54 as the rear is slightly geared down i guess. you ever find those lugnuts btw?
