btchscott
Location
Redding, CA
Referral
Google, side differential retainer
Biography
Do it your self mechanic trying to research a problem
Vehicles
1997 Subaru OBS
btchscott's Achievements
Newbie (1/11)
0
Thanks I will be removing it . opening it up jut to see what We did wrong Hope to do better on the next one
- 15 replies
- OBS
- 5 speed transmission
(and 1 more)
Tagged with:
Sorry it took so long to post these pics. Family Medical situation came up and I was just able to get things apart to take these pics as you can see in the photos the ring has cracked on one side and broken a chunk out of the other. We checked the length of the old axles and they appear to be the same length as the new ones. There is also a lot of movement on this axle stub, almost an inch. Thanks to all that have posted and given us a direction to look any further advice is greatly appreciated as we have no idea why this is happening.
- 15 replies
- OBS
(and 1 more)
Tagged with:
Thank you one and all I will be getting out in the next dry day to get the axles out to measure the to the old ones I still have them in the boxes. I will get photos at that time
- 15 replies
- OBS
(and 1 more)
Tagged with:
No Noise and we did not even get 300 feet A better way Describe it is that they break and tear the seals It is possible that the axles are too long: Yes I got them from Rockauto
- 15 replies
- OBS
(and 1 more)
Tagged with:
OK I have read a lot about the side differential retainers and how they set the differential pre-load. My problem is they keep shattering on my transmission. First lets give some history. I removed the engine and transmission to rebuild the motor, and found that the throw out bearing was shot. I also found that there was a lot of play in the input shaft. So my son and I decided we were going to attempt to rebuild this transmission. We watched several videos and did a lot of research into disassembly and reassembly of the transmission. Once we took the transmission apart we found that one of the bearings on the input shaft was toast. Since we had the transmissions apart we decided to replace all the seals, o-rings and gaskets. This meant removing the Side Differential Retainers, knowing that not getting them back into the same precise location would change the differential bearing pre-load and pinion gear backlash we marked a tooth and the housing of the transmission with paint so we could realign it to the same place as before the tear-down. We counted the rotations it took to remove them and reversed the process and reassembled the transmission. Everything was going fine on the test drive until I got back and saw that the car was leaking gear oil out of the side of the transmission. Upon closer inspection we found that the Side Differential Retainer was broken and the seal was destroyed. Thinking that we put the wrong seal on the wrong side, we replaced the retainer and the seals making sure that the right seal went in the correct side. But after the second test drive the same thing is happening. Can anybody give me any idea what I am doing wrong or some place that I can look to find out why this keeps happening. Thanks
- 15 replies
- OBS
(and 1 more)
Tagged with:
