rogerz
  • Location
    Seattle WA
  • Referral
    google
  • Biography
    engineer
  • Vehicles
    2005 Outback
rogerz's Achievements
Newbie
Newbie (1/11)
0
  1. 05 outback wagon base model. Put new front axles and shocks. NOw I get ABS light, check engine light, seat belt chime even tho plugged in and cruise control keeps flashing. New battery fully charged. checked the fuses that are indicated for the abs system and ecu. battery was disconnected when the ;mechanical stuff was done so not likely a blown fuse. tranny locked in park unless you push down the secret button to unlock it. brake fluid full up. brakes work but no abs. drove over a mile at about 40 to a parts store. they tried to reset computer but just goes back to check engine, speed sensor A indicated as problem. Any thoughts welcome
  2. 2005 Outback about 100K. standard engine auto. When just sitting there I get around a half amp draw from the battery. pulled all fuses inside and engine compartment with an ammeter attached to monitor draw. NOthing. except back up lights showed slightly less draw. Any thoughts on usual problems with this car. best place to look for possible slight ground?
