Everything posted by njdrsubaru
5spd manual AWD question
hey guys ive just finished my 5spd swap on my outback... now it feels like the tras doesnt have AWD... today is raining here in the NE, when i tried to take off from a stop light the front wheels were spinning and no traction to the rear.... is there something wrong with this trans? there is no torque bind
5 speed swap :)
njdrsubaru replied to 95legwagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthe bolts were the same for the rear part of the crossmember, the front ones i had to look for new 17mm bolts.... thank god i have countless cans of subaru bolts lol did u end up getting the p1101 code?
97 outback auto to 5spd swap
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok I'm not quite done yet I have a p1101 cel does anyone know how to get rid of this code? it's the neutral switch malfunction.... do I have to run a wire from somewhere to one if the ecu pins?
- 97 outback auto to 5spd swap
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXtru true... i dont have any problems as of right now but i still have a cel of p1100... i didnt have anyone to take pics for me but i'll do a write up of the steps, problems ive encountered and parts i needed to get from the dealer... i can say one thing, if you drop the engine and trans married at once its a hell of alot easier... ive done many autos in the past but this is the easiest one i have ever done. info to come...- 97 outback auto to 5spd swap
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think I won't have too much problem with the cel... I have a 5spd ecu but I'm not there quite yet I have a few things to button up today and hopefully fire it up... I guess tomorrow will be a junk yard hopping day to find that shifter rod- 97 outback auto to 5spd swap
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXahhhh evrything went well except that the person who got me the 5spd swap kit gave me the wrong shifter rod... i need a new correct one anyone has one?- 97 outback auto to 5spd swap
hey guys and gals so ive created some b...s and started my 5spd swap prep... all parts have been collected and clutch kit will arrive on monday... ill keep yall informed how it goes and im sure im gonna have tons of questions ill place pics as soon as i get it all apart- EJ20 question....
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXactually I know they are jdm... it's in brazil, south America.... subaru started selling legacies there in 1991 with the ej18 and ej20 so that means all the NA ej20s up to 98 are non interference that's what I though thanks guys btw all the AWDs and dual range!!! yummy I'm looking into a 96 legacy wagon gx looks good but again I need to be there to buy it so it's gonna have to wait till I go see my mom- EJ20 question....
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXeven the ones from the 90s? I thought those were based on the ej22- EJ20 question....
so im buying a subaru in another country so i have a car there when i go there... are the JDM EJ20 from 94 to 98 non-interference?- ej22 misfiring...
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXdoh! it started doing it again today.... im gonna replace the ecu next and see if it gets better.... compression checked in all 4 cyl... im running out of options- ej22 misfiring...
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok this is the second day after replacing the intake manifold gaskets and still no sgn of misfire when starting cold or warm- ej22 misfiring...
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just replaced the intake gaskets lets see what happens I'll keep everyone informed- ej22 misfiring...
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXno cel... it misfires then if pu rev it up for a bit it stops as it goes back down to idle- ej22 misfiring...
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit happens after I drive, park and let it cool down a bit then when I try I start it misfires for about 20 seconds or so or until I step on the gas reving it up- ej22 misfiring...
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok i changed the CTS and still doing it now... can a intake manifold gasket do this?- ej22 misfiring...
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi was thinking about that CTS...- ej22 misfiring...
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXo2 and knock wouldnt have a misfire symptom it could run a bit lean or rich but not misfire like it is now how about the AIC?- ej22 misfiring...
it usually happens when i first start in the am or after a drive it misfires for about 45 seconds and it idles fine now i have already replaced the following: plugs, wires, coil, ignitor, injectors, fuel pressure regulator, fuel pump im out of options- so im tired of my slushbox, need 5spd swap info...
i am toying with the idea of a 5spd swap... i have 2 working autos but the reality is that they are more trouble than it is worth... i hve done a search here my didnt come up with anything substantial i need wiring info so i dont get a CEL on after the swap, ABS wiring info and any helpful tips this is being done to a 97 outback, mind that i already have matching rear diffs all i need is to get a 4.11 manual trans any info is much appreciated thanks- What evils shall we find in the New Jersey Pine Barrens
- 2.2 into a 97 OB swap info needed
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXsuccessful swap now onto the AWD binding problem- 2.2 into a 97 OB swap info needed
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks... I'm gonna have lots of taupe body parts for your wagon, same color 8)- 2.2 into a 97 OB swap info needed
njdrsubaru replied to njdrsubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks guys I'm working on it right now... - 97 outback auto to 5spd swap
