dilly
Location
N wilkesboro N C
Referral
relays
Biography
need help with my '84 Brat
Vehicles
'84 Brat
dilly's Achievements
Member (2/11)
Pull the engine or not to replace clutch
dilly replied to dilly's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thank you for the help..( a bunch ) -
Saw a video some time back of replacing clutch on '84 Brat..He lowered front of engine and raised back of transaxle..Can't find it now ? Is this reasonable to do or just pull the engine ? Appreciate any advice
2 different garages have looked at this little truck and surrendered ? New dist., new switch..Need to ask somebody ? Last garage said it was a California car with a computer and possibly it is at fault ? I've looked under the seats and I can't find a dang computer on it ? Any suggestions or help will be greatly appreciated ..Thank ALL of you for your prior posts..sincerely
Thank you for your response ..Replaced distributor (253,000 on engine), replaced ignition switch ? Have fire in on position to coil, but when I go to start position, I lose fire at the coil ? Not having any luck with those 3 relays located near coil ? Not sure what is what ? Have looked at a few other Brat's, and not wired same as far as these relays ? Wonderful little truck..Problem started suddenly..Engine die suddenly.No warning, no hesitation, just die..Crank right back till next episode..Now won't crank period ? (changed coil )..I just not sure what to do mister ??
