Torrito
Everything posted by Torrito
  1. Just took a look at the invoice, it's the OEM 10105aa790 set and the x13028aa21bk timing belt kit. The labor included replacement of the rings, main and rod bearings, cams, crank and timing components. Resurfaced the heads and block cases, grind/polish crank, bore/hone cylinders. Should I list it was 3k miles on the vehicle or the 127k indicating it's a rebuilt engine? Thanks again!
  2. Subaru Clinic in Broomfield off 120th did the rebuild. Ill share the details when I get home and can look at the invoice but I know for sure the heads were resurfaced. Thanks again for your time!
  3. Thanks a ton for the insight. I'm not terribly knowledgeable in this area so saving me from a 600 dollar fix is very much appreciated. Do you guys think I could get 5 for the car? Does a rebuilt engine(still has 7 months on its year warranty from the mechanic) take away from the value?
  4. Hey everyone, I'm hoping to get some feedback on what to do with my 05 Legacy sedan. It's not the limited model but does have a rear spoiler so I'm not even sure what package it has. I bought the car in 2013 with 92k miles on it and did the gaskets at 105k for 3 grand in 2014, and last August blew the engine which I repaired for 4.5k. I've had so many problems with the thing and want to sell it with 127k miles on it currently. I'm in Colorado and it does do a great job in the snow, so at least subarus are hot here. There's still some work that needs to be done. The steering wheel shakes a lot when exiting highways and braking(rotors I assume for another 600 bucks), the tint on the back window is bubbling, drives side window switch broken but functional, climate control knobs never set properly from the last mechanic and won't pop into place. The windshield is also cracked at the bottom but is hardly noticeable. With that being said, should I sell the thing as is, and what do you think I can get for it? Should I make any of the repairs to not see a return? I've just had so many problems with this thing and want a more reliable vehicle. Thanks for all your help.
