153
Everything posted by lmdew
If I turn off the AC when I feel the cooling going down and leave it off for 5 minutes or so and turn it back on all is good. I pulled the Fan and Evap Cover to take a look at it. You can see much, but it looks like new. I'm going to talk to the AC Shop and see what they think. Put it back together if they don't have a solution. I don't want to throw parts at it. Boy I miss the 90 fans you could pull with a few screws. Clip together plastic everything, on the 2002 and later, I'm sure.
2002 Impreza, the compressor had locked up, so I put a used one in. It worked fine for a few weeks. Then the AC stopped blowing cold air after 30 minutes of use. High pressure line leaking. I changed it with the one off my 2005 Impreza. I change the o-rings, Compressor and Condenser. I had a service center pull a vacuum and service it. It worked fine for about 30 minutes and then stopped blowing cold. The Low pressure return line was frosted up again. Evaporator? So goes the island beater. Thanks, Larry
Island beater, low mileage 2005 Impreza Wagon. Nice cold AC. I was hit in the front before I got it. Low mileage, but no history on the T-Belt. I pulled the covers and it looked pretty new and there were marks on the cam and crank gears. OK, no need to change so I put it back together. As I was putting in the fans, I noticed the AC Condenser was rubbing up against the radiator. OK I can fix it. I repositioned the filter clamp, so it provided some additional room. All back together and all is well. The next morning no cold air. No signs of leaks, so one 12oz charge and it lasted for a day. New condenser ordered.
Well, since you said "Fired right up after timing belt/water pump kit was installed, but when all was reassembled, car misfired then would not start." First thing I'd check would be the T-Belt. Make sure the timing is correct! Yes you should hear the fuel pump run when you first turn on the key for a few seconds. Subaru fuel pumps are much better than aftermarket pumps! You can just put a little gas into the intake and see if it fires up to check and see if it's Fuel or Spark.
Better half said the AC was not working. When I got back on island, I took a look. The belt was broken the compressor locked up. The tensioner was was not turing freely. A quick trip to my island parts supply and I had used parts. I bolted everything up and charged the system and it seems great! Sweet
Buy a rust free body and drop your good driveline into it. Crazy amount of work. What was the costs?
