153
Everything posted by lmdew
Most likely you have missed timed it. The crank gear used the tick mark on the back of the pulley. I would recheck the timing before you drive it any more. Did you turn it over by hand once the new timing belt was on to make sure everything lined up and there was no piston to valve interference? Hopefully you did not bend valves. Why were you replacing the water pump? If it was for overheating, you may have other issues.
Pretty much any Subaru will bolt to any transmission. You will need additional parts and there will be wiring to correct so it's not just bolt in and go. Drive Shaft may be a different length Trans mounts are different This is a pretty labor intensive change if your auto trans is working. If you really want a standard transmission car it may be better to sell your auto and purchase a standard.
- 5 replies
- Transmissions
- Differentials
(and 1 more)
Tagged with:
Lot's of You Pull and Pay Yards up your way. www.car-part.com Or swap to a manual 5 speed trans.
Did he check the input shaft for play? I just dropped a trans out of an 01 Forester the inner hub of the clutch disk was completely severed from the outer disk. The shop that surfaces my flywheels said it looked like someone downshifted at high speed. The input shaft to the trans also had lots of fore and aft play. Used Trans going in along with a new Clutch Kit.
I grabbed a trans from a 02 Outback for a 01 Forester. The forester has the old style suspension found on 90-99 Subarus Legacy's. The original trans was a 4.11 but the Outback was a 3.90. So I had to swap the rear diffs as well. I didn't know for sure they would fit, but all bolted up well and it's going down the road. The new style suspension was harder to get the rear diff out, as the side play to pop the axles out was not near what the older style is. Hope this helps someone down the road. Larry
Do you have VVT? I changed a fellow cam and crank gears for him to get his engine swap going and the drivers side cam gear had 2 yellow dots and lots of tick marks on the face. I matched it to an old cam gear with a single tick mark and the tooth between the yellow dots match up so that is were I set the timing. Ran well.
I had the bolt out so I drilled up from the bottom to locate the hole. Mine was on the drivers side. If you can't get the bolt out, just measure over an inch or two and drill up from the bottom to locate the hole. You can use an 1 1/2 or 2" hole saw and drill from the top down. Then just put in a plug. If you ever have two remove it again, no problem.
I picked up a 00 Forester 210K on it. It runs good but the clutch was completely out. PO said the trans was out, didn't move at all. Not even a little drag. I pulled the engine and trans today, the clutch friction material was completely free of the center hub. It was an aftermarket clutch (South Africa stamped on it). It does have the aftermarket input shaft sleeve and throw out bearing. I can move the input shaft about a 1/4" in and out. The side play is slightly more than normal but not to bad. The forward and aft movement is bothersome. The Trans Code is: TY755VC1BA = 4.11 I do have a spare trans TY754VCBCA = 3.90 So a few questions: 1) What sets the play in the input shaft? I have no idea what happened or if there was any strange noise before it quit. It seems to shift well and all of the drive shafts move as normal. 2) If I swap to the 3.90 and put in a matching rear end, how can I correct the Speedo? 3) Is it worth splitting the cases to fix the input shaft play? The gear oil was a little dirty, but not to bad, no chuncks and just heavy fuzz on the plug. Thanks, Larry
