153
Everything posted by lmdew
Well you say trunk and then hatch. Sedan's have trunk lids, Wagon's have a Hatch. Sedan, you should be able to go through the rear seat and get into the trunk to pull the release. Wagon, you need to pull the lower panel off the inside, about 8 little plastic buttons across the bottom and then pull it off. Once in you can manually release the latch. Before you do all of that, push down while someone does the electronic locks for you a few times.
It's only $2.00 at The Subaru Dealer. The EJ22 does not have the HG problem the 96-99 DOHC engines do. the newer 2.5 SOHC engine call for the conditioner.
- 8 replies
- EJ22
- coolant conditioner
(and 1 more)
Tagged with:
Thanks, that's what I was thinking. It took 13.6 gallons yesterday, the gauge was just over a 1/4 and the low fuel light was on. It only went up to 3/4 so there is something going on. The fuel pump side may not be the original unit as it did not want to set flat in the tank when I pulled it to clean the sensor. the front was up a 1/4" or so, it felt like the filter was up against the bottom of the tank. I'm thinking the OP may have changed it out trying to fix the problem. I'll have to check the PN when I get time to ensure it's the correct unit.
Cleaning the sensors helped but I don't think it fixed the fault. The Low level sensor light came on today, with 3/8 of a tank. It went back off in a bit. I have not filled the tank yet to see how much gas it will take. I'm going to run it until the low level light is on steady or I'm at E. I think they are wired in series as when I disconnected either one of them the tank went to E. Larry
engine swap
lmdew replied to Chippy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It's possible, use your old intake on the new engine. Your 96 most likely has a single port y pipe and the 91 has a dual port y pipe so you'll need a single port y pipe. The other problem is the EGR Configuration. you need to stay in the same configuration as the 96. -
Least expensive and a good option if you can do it yourself, get an engine from a self server yard and put it in. Do the Timing belt and seals. Look for a car with significant damage and lower mileage that way you know it was going down the road. $400 - $600 Get a used engine from a full service yard - www.car-part.com $1000 - $2000 Have a Subaru Engine Shop rebuild your current engine - $1500 - $3000 Sell the Car ($800 - $1500 depending on condition) and then replace it $$$$$$$
3/4 = 1/2 & 1/2 = Empty - Fuel Sending Unit 98 Impreza I have not pulled the unit yet, but it's kind of strange that it's reading so high. The fuel low level light does come on but it's still showing half. I'll pull the unit when I get time and clean the contacts and make sure the float is free. Larry
engine swap
lmdew replied to djmark7's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Is your 99 the 2.5 DOHC? If so yes. Seen EGR notes in the previous post. Larry -
The internal filter is really not a filter it's a screen. You most likely do not have the external filter, its available from Subaru. It mounts to the frame rail and you tap into the rubber hoses. Don't bother dropping the pan, in fact most times it causes a leak. Only drop it if it's leaking to reseal it.
1999 outback
Yes, 96-99 will interchange. Check out the Colorado Springs Craigslist - rust free CO Car $1400. Larry
