lmdew
    153
Everything posted by lmdew
  1. Well you say trunk and then hatch. Sedan's have trunk lids, Wagon's have a Hatch. Sedan, you should be able to go through the rear seat and get into the trunk to pull the release. Wagon, you need to pull the lower panel off the inside, about 8 little plastic buttons across the bottom and then pull it off. Once in you can manually release the latch. Before you do all of that, push down while someone does the electronic locks for you a few times.
  2. It's only $2.00 at The Subaru Dealer. The EJ22 does not have the HG problem the 96-99 DOHC engines do. the newer 2.5 SOHC engine call for the conditioner.
  3. Once it starts in those areas it's very hard to stop. No panels that I know of. The Wheel Wheel rots due to the cancer all the way at the top of the strut tower outside wall that lets moisture into the inner fender. Get a rust free CO Car. Larry
  4. Thanks, that's what I was thinking. It took 13.6 gallons yesterday, the gauge was just over a 1/4 and the low fuel light was on. It only went up to 3/4 so there is something going on. The fuel pump side may not be the original unit as it did not want to set flat in the tank when I pulled it to clean the sensor. the front was up a 1/4" or so, it felt like the filter was up against the bottom of the tank. I'm thinking the OP may have changed it out trying to fix the problem. I'll have to check the PN when I get time to ensure it's the correct unit.
  5. Anyone know where the ground point is for the fuel sending units? 98 Impreza L Wagon. I don't have the wiring manuals with me. Thanks Larry
  6. NGK Plugs and NGK or Subaru plug Wires! Coolant Temp sensor may also be a factor. CEL ON?
  7. At just over a 1/4 tank now. I'm going to see how much gas it takes in the AM. That will give me a good idea if the fuel level is now correct after cleaning the resistors of the sending units. Thanks Larry
  8. You can have the system pressure checked. or bypass the heater and see if the leak stops.
  9. Cleaning the sensors helped but I don't think it fixed the fault. The Low level sensor light came on today, with 3/8 of a tank. It went back off in a bit. I have not filled the tank yet to see how much gas it will take. I'm going to run it until the low level light is on steady or I'm at E. I think they are wired in series as when I disconnected either one of them the tank went to E. Larry
  10. www.car-part.com shows a nice CO Rust Free one: 2002 Muffler Subaru Legacy LL BEAN,3.0L,EFI,AWD A BB001 $Call Brighton Auto Parts USA-CO(Brighton) E-mail 303-659-2965
  11. It's possible, use your old intake on the new engine. Your 96 most likely has a single port y pipe and the 91 has a dual port y pipe so you'll need a single port y pipe. The other problem is the EGR Configuration. you need to stay in the same configuration as the 96.
  12. Pulled both sending units tonight and cleaned the slip ring with a little WD-40 and finger pressure. Both read 500 Ohms Empty and O Ohms at Full. Time will tell if that takes care of it. Smooth resistance changes as the float moved full scale. No Opens. Larry
  13. You have some great You Pull and Pay Yards up by you. $250 for the engine and a couple of days of work. Out of all the engines I have pulled I only got 1 bad one. That engine I pulled from a crash free car which I usually never do.
  14. Least expensive and a good option if you can do it yourself, get an engine from a self server yard and put it in. Do the Timing belt and seals. Look for a car with significant damage and lower mileage that way you know it was going down the road. $400 - $600 Get a used engine from a full service yard - www.car-part.com $1000 - $2000 Have a Subaru Engine Shop rebuild your current engine - $1500 - $3000 Sell the Car ($800 - $1500 depending on condition) and then replace it $$$$$$$
  15. 3/4 = 1/2 & 1/2 = Empty - Fuel Sending Unit 98 Impreza I have not pulled the unit yet, but it's kind of strange that it's reading so high. The fuel low level light does come on but it's still showing half. I'll pull the unit when I get time and clean the contacts and make sure the float is free. Larry
  16. Is your 99 the 2.5 DOHC? If so yes. Seen EGR notes in the previous post. Larry
  17. Yes, you can split them or pull the complete drive shaft and take it to a Drive Shaft Shop they will be able to rebuild it for you.
  18. If the TC is seated and in, I'd just leave it. If you've pulled the TC you don't have to change it but it would not hurt. Leave the axle seals unless you see damage.
  19. The internal filter is really not a filter it's a screen. You most likely do not have the external filter, its available from Subaru. It mounts to the frame rail and you tap into the rubber hoses. Don't bother dropping the pan, in fact most times it causes a leak. Only drop it if it's leaking to reseal it.
  20. You'll have to get under the car and check the Trans shift linkage u-joint. There are a couple of different configurations.
  21. Yes, 96-99 will interchange. Check out the Colorado Springs Craigslist - rust free CO Car $1400. Larry
  22. Don't forget to tighten the lower engine stud nut when you are all done. If you don't find a good head I have a set in Colorado Springs. Larry
  23. Load, Ground, Power. The three keys to a good electrical circuit. Check out the Load Pro. www.brighterideas.com Dan has some great electrical troubleshooting videos on youtube as well. Search LoadPro. Larry
