153
Everything posted by lmdew
I picked up a 2005 with a rod knock. Not bad but needs to be rebuilt. Found a 2006 with only 58K on it, It was not cheap but with only 58,000 miles I went for it. When I pulled the old motor and had it next to the new one the differences became clear. The Drivers side head has an extra sensor on it, the exhaust is different.... I think I'm leaning to selling or finding a car that needs the 2006 and getting the 2005 rebuilt. Thoughts?
Check the coolant level at the radiator when the car is cold. If it looks fine, bring the car to temp and then check the heater hoses in the engine compartment, are they both hot? If so you have coolant flow through the heat exchanger. Temp gauge in most subarus run at the 1/2 mark. A little below is no big deal. Thermostat may have been changed out. If you put a new one in, get a Subaru Thermostat. I've pulled a few of the heater boxes and don't remember a cover or slot where your hole is. I'd suspect broken plastic. Did someone pull the AC Evap core by chance?
Do they mean the camber was maxed out? The front struts top bolt is adjustable. The rear's do have camber bolt kits you can buy. I've never used them. I have put a smaller dia bolt on the top on the rear to adjust for Forester Struts on a Impreza. It works well and I've never had a problem. Make sure your Struts are not bent, sometimes it's hard to tell. Full adjustable struts are available but $$$. The top mounts move in and out.
The IAC may help. They have slight differences Auto to Manual. You can try adjusting it by marking the location and then loosen the 2 screws and adjust. The other problem you are going to have is if the engine did not have the EGR Valve. It will throw codes. Search the form, lots of good info on this.
Contact cleaner will not clean the electrical contacts of the Ign Switch. If you end up needing one, I have one with keys. You will have to drill the heads off the bolts to get the ignition switch assy out. Make sure you don't have an aftermarket security system as I've seen these cause many problems.
Son had another coil from his buddy's car. 4 pin connector. It started running on all 4 but then would not rev above 2500. Very Strange. I went up today, bolted on a use Subaru Coil I had, Problem Solved. Lessons learned, Only use Subaru Coils and NGK or Subaru Plug wires. Back on the road. Thanks Larry
Use the search function and you will find may post on this. - Car up very high on good jack Stands - Trans is very heavy a good jack is needed - Don't dent the pan jacking on it - Make sure the TC is fully seated - You may have to change the flex plate to match the TC - 2 different sizes - 12mm 6 point socket for the flex plate bolts - support the engine when the trans is off - check the condition of your trans mount, you may need a new one - pull the complete exhaust in one piece if you are in the rust belt. - Make sure the front and rear diff gear ratios are the same
Push the TC back into the trans once the 4 bolts are out of the flex plate and then make sure it stays fully seated. I've found that when fully seated the TC will lightly rub the Starter teeth when you push it back and turn the TC. Easy way to ensure it's fully seated. Will likely need new TB Cover Seals, at least the bottom one.
