153
Everything posted by lmdew
So the car will start and the Battery is charging when the engine is running? Have you checked both fuse boxes, the one in the engine bay and the one under dash? Check the grounds in the engine bay, up on the drivers front corner and behind both struts. Battery terminals good and clean? Has this been going on for awhile or did it just happen?
Have to lower the rack some or pull the steering column back. I'd go with the rack. drop the exhaust, just off the engine is enough. Remove the jack pad on the cross member, Remove the 4 rack bolts. Then it's just pulling the 12mm ujoint bolts. Assemble in reverse order keeping the steering wheel and front end in the same positon.
I pulled a 95 2.2, non egr today with 191K on it. The PO took care of the car and the compression felt good. I needed on with an EGR and the head was not drilled for it. (I know it can be done, but I didn't want to mess with it). So if you need a good 2.2 for your project all you have to do is hit the DEN UPAP row B1, green wagon and pick up the engine.
I have a 98 that at one time had the Subaru Security system in it. It was removed at some time. All of the doors except the drivers door lock and unlock with the push button on the door panel. I checked under the dash and behind the kick panel, the blue wire going to the drivers door lock has an open, but I can not see where it goes as it's inside a pretty good wire bundle. Anyone have the FSM Wiring they could send? The door lock will lock if I provide a ground on the blue wire as the green wire has 12vdc. Thanks, Larry
When I pull them out at the yard, I'll pull the car side of the harness connectors as well so you can see where they plug in on the new car. Works well. Wish I had one now, as the car I'm working on had a system but someone pulled it and now the Drivers door does not lock and unlock with the door lock/unlock button. Power down to the plug in the forward kick panel but no ground. The ground must have been cut when the security system was put in. I have to hunt one down.
Hauled a 17' glue lam beam 12" x 5.5" over 100 miles on the freeway on the Legacy Outback. Road as nice as could be. Have had 15 sheets of 1/2 OBS on top in town. 2 washer dryer sets, one machine on top, 3 inside. As long as you have it strapped down well and don't drive crazy you're OK. Of course plenty of stopping distance between you and the next car is wise.
