lmdew
    153
Everything posted by lmdew
  1. Glad you got one. I have the same pipes used in nice rust Free CO condition. I sent one out last week for $60 shipped.
  2. Anything is possible, but dual failures at the same time are unlikely. Auto Trans? If you have torque bind and had weak/worn joints it's possible. Pull them off and make sure the stub shafts are OK. You might also drain the gear lube and see if you get metal.
  3. Take a angle iron about a 1' long and drill 2 holes in it that match the drive shaft bolts off on one side. That will allow you to lock up the rear diff input and then you can brake the nut loose. I have one dripping also, I have to get to it sometime.
  4. Could have jumped teeth. I'd pull the covers and check. Auto or Standard Trans?
  5. I have a good low mileage rack from a 95 Legacy with 95K on it. I just used the inner tie rods, but the rest of the rack is there. If you have good tie rods and boots you'd be set. $20 + Shipping from CO 80916 Larry
  6. A while ago I purchased a low mileage set of hubs thinking I'd need them some day. I took them out of the box today and they are the style that has the ABS tone ring on the axle. Anyone know what years and models used these hubs? Thanks Larry
  7. Auto or manual Trans. I think I have both starters. If you can send a picture I can match it up for sure. Larry
  8. Yep, JB weld should do the trick. If you want a new pan I have some good ones. $50 shipped.
  9. Did you replace the dipstick O-rings? Did you use RTV or a gasket? Did you check the pan for dents or over tightened bolts and straighten them out. I have good pans if yo need one.
  10. Most likely the car was hit at some point. Jack the car, remove the rear tires. Remove the mud flap bolts Remove the 10mm bolt inside the rear fender well towards the front corner of the cover Now you can pull the sides out and see what is up with the clips. They snap on a pin. If the pin is missing or the clip damaged they will stick out. If there is damage, you can see it inside the rear hatch, pull the L&R side carpet and pull the round covers for the bolts. Pull the bumper by removing the 2 bolts on each side and slide the complete bumper off. You may have to pull a few bolts, plastic pins on the bottom of the bumper to frame as well.
  11. I have a complete rust free fuel tank with sending units and pumps. Your's for $80 + shipping. I can strap it to a pallet and ship it to you. If you have a business address or can pick it up at a freight dock that would help. My fuel smell was solved by the fuel filler neck. The one I removed only had a little surface rust, but the smell went away with the new neck. Larry CO 80919
  12. I have a R Front that was flagged. I changed the sensor as the tip was broken. The new sensor still read open. The connector was worn, once I cleaned and tightened the connection it was good back to the ABS unit. I have spare rear's if you need one. $20 shipped.
  13. Get the CEL Codes, even if the CEL is not on, you may have codes stored. Once you have them written down, clear the memory. Make sure you've taken care of the basic maintenance, clean battery terminals, cleand body and engine grounds...
  14. Hit one of the You Pull and Pay yards. Complete Strut is about $25 and It will bolt right in. If you look, you will find KYB struts someone put on recently. $700 is crazy. Hope he did an alignment for that price.
  15. Do a search for the swap. Legacy 77 has a great post with all the details. A little wiring is involved but it's not bad. I've done a couple. You have the parts listed. Larry
  16. The ECU will correct based on the O2 sensor so I would not worrry about it.
  17. Plastic tanks are the failure point. If it overheats they seem to fail faster.
  18. www.car-part.com They are not that bad to change. You need to drop the headliner some for access to the bolts. The wiring harness needs to be pulled through the body as you remove the hatch. When you do that on the are you are going to install it on tie a string or wire to the harness so you can pull the new one back down.
  19. Pull the valve and make sure it's working properly and not blocked. Check the intake to make sure it's not blocked. Remove the hard line head to ERG and clean it if needed and check the hole into the head. The Knock Sensor will make it run poor, so fix that one first.
  20. The clock springs are a little different but the steering wheels interchange. I have a good steering wheel from a 98 Outback that will bolt right up. Larry
  21. If you need a good muffler I have a few. Shipped from CO so that will be a bit. Are you running 5w=30w? Make sure you do not have a FRAM filter as well. New Oil change and some operating time will quite down the lifters if that all it is. Larry
  22. The easy way to do it is to replace the hub bearing and all. Get a good used on and bolt it in.
