Everything posted by lmdew
06 Forester Hillholder not releasing
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep, that will most likely be the solution.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSpring is there and there is slack in the cable. Thanks
Betterhalf was driving, and said the Forester was acting strange. I got in and it had a huge amount of drag as I let out the clutch. Pulled off the expressway and popped the hood. Yep the hillholder was not releasing. No tools other than the Subaru kit in the rear. I was able to get the hillholder cable retaining clip off the bracket and open the hillholder completely. Problem solved and we made it home 80 miles. I may just leave it disabled if I can not get it working properly.
08 Outback PO340 Cam Sensor
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell I was going to get it Friday. Had cash in hand and then the Dealer's Sales person said the owner had already committed to trading in the car on the new one. Deal Stinks! $500 for a 2008 with 120K on it, but they told her it needed about $10K for a new engine. I'd tell them to keep the NEW Subaru!
Non rebuildable 05-07 legacy/out/tribeca starter solenoids
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI hate when you can't service normal wear parts! Throw away life.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDealer said they needed a new engine. I might be able to pick it up. Used engine...
2006 driver and passenger windows rattle
lmdew replied to foxgap's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBest option is to go to a yard and pull a door apart there. The top rub pads can usually be adjusted but they push the glass out. You may create wind noise. A good inspection is the place to start.
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, that's what I thought. It must be that the passenger side cam gear failed. Owner runs by my place sometimes so I hope to hear what the failure was at some point. If so, I'll update the post.
I stopped to help someone on the road today. The car would not start. I pulled the codes - 08 Outback PO340 Cam Sensor. When I pulled the driver's side small timing cover there was over a foot of slack in the timing belt before it stopped. They had the HG's done a few months ago. That much slack, I would think the passenger side cam had failed. GD - those plastic gears you've talked about?
02 Impreza Fuel Gauge Inaccurate Reading
lmdew replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPull the access covers and soak the studs with PB Blaster. That way they will be ready to go when you want to pull them. Fill the tank and go by mileage!
lmdew replied to Daskuppler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are two sensors/resistors one on each side of the tank due to the driveshaft hump. The resistors can become iffy. There is Fuel Sensor cleaner you can add to the tank. If you pull the sensors out, make sure you do not snap the 8mm studs on the tank. If the car has rust issues, I'd just leave it as is.
Loveland, CO - Who's the local 'Subaru Guy'?
lmdew replied to beamsbox's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShwan is in your area, but I don't know that he is taking on any work. Super Rupair www.superrupair.com 1309 Yarmouth Ave, Boulder, CO 80304 (303) 442-6508 Very good.
Engine shutters briefly after fill up
lmdew replied to Charlie B.'s topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGD what is you stop limit on Subaru years cars? I told my brother nothing newer than 2006. Thanks
2003 Forester- any good replacement headlight housings?
lmdew replied to Stevo F's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com
'99 OBW high beam relay location?
lmdew replied to jonathan909's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are in the engine compartment fuse box.
1998 Forester clutch pedal in "hot" Alaskan weather
lmdew replied to Ravenwoods's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNew hose and brake fluid. Bleed it wall after the hose change.
98 legacy outback wagon, wwyd?
lmdew replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou should have Dual Port Exhaust on your DOHC 2.5. - a 95 2.2 has dual port exhaust. 96 -98 2.2 are single port exhaust so you'd need to change the y pipe. Most junk yards cut those as they take off the CAT so you'd buy a new one. EGR, the best is just to make sure both engines have one.
lmdew replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes. If you can match the EGR and Exhaust ports. Easy that way but there are work arounds. Much cheaper to put in a used 2.2 than do the HG on the DOHC.
lmdew replied to xdeadeye1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX2.2 swap!
Hunting idle ej22
lmdew replied to bbrow632's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you cleaned the intake? Seafoam works well.
EJ22 no start, good fuel, cam sensor code
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOK, I'll get them out ASAP. Anything else?
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have New tensioner's as well. New style.
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have spare sensors if you want some. I like the old style tensioner and have swapped the bracket to put them in.
06 Outback Lifter noise?
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the info!
Marketplace - 2006 Subaru Outback · 2.5i Wagon 4D | Facebook 178K mileage. Lifter noise? $2400 it looks clean and is CO car.
