Everything posted by lmdew
4EAT Transmission Repair
lmdew replied to beanyo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust hit the yard and drop the pan and grab what you need. I pulled one for my son's 99 Outback and the yard charged $15.
5 speed swap question
lmdew replied to 95legwagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo a search with my user ID Lmdew. I have a post out there. It's a few years old. I did one and then a couple of years later I did a search only to find my own post. Larry
Help! 1999 Subaru Outback in Distress! Clutch Pedal is Dead XP
lmdew replied to DirtyMech's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have had good success with flushing the old fluid out and bleeding the system. NOTE: keep clutch pedal in the normal range as someone already said, if you let the master go into a new area, it can damage the seal. Same goes for the Brake MC.
1998 Forester thumping sound
lmdew replied to Fozester's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave you tried swapping the tires?
98 Outback Power Antenna
I found a good antenna, It goes up and down, but ratchets at the ends. I cleaned the mask with WD-40. Still not extending fully and ratchets at both ends of the drive. How can I re index it?
99 legacy obw low/rough idle with audiable miss but no code
lmdew replied to DCRB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIAC may need a cleaning.
driver seatbelt stopped working
lmdew replied to whiterabbit's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThese fail pretty often. It is driven by a motor at the bottom of the door at the aft side. Lots of times the cables come out of the track. Once that happens, you pretty much have to replace the complete unit. I've worked the cable back into the track but it doesn't last to long. If you can get it into the aft lock position, you can just undo it every time. Units are $25 at the local pull and pay. There is a manual retract option, the allen wrench is in the center counsel. Get out the owners manual.
2003 Forester 2.5 SOCH Engine - What Years
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for all the information. Now I just need the $1000 subaru that needs the engine. Larry
98 Legacy Outback Alway ON - Runs
I picked up a 98 Legacy Outback. It was hit in the drivers front. I replaced the radiator, got it running but now it will not shut off. If I turn the key off, it keeps on running. I have to disconnect the negative battery cable to get it to shutoff. When I hook the battery back up it like the ignition is already on even though the key is not on. It does have the Subaru Security system. I take it a relay is stuck on. Where's the relay? Thanks, Larry
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, now all I have to find is a great deal on a Subaru with a bad engine!
I picked up a good 2003 SOHC 2.5 engine from the local yard. What will it drop into? I searched car-part.com for an engine and the only year that came up was 2003. Thanks, Larry
Help! Leaky fuel tank in a 1996 OBW. How dangerous?
lmdew replied to MischivousSlpwlkr's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a like new Tank and filler neck if you need them. I"m in CO. Rust Free!
Acts like slipping clutch, but not so sure...
lmdew replied to detwiler007's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck the drive shafts and differentials. I've had a couple of Subaru's where the axle popped out of the Diff a 1/2" or so and it feels just like the clutch is slipping. Look at both end of the half shafts and give them a good tug. If you don't see anything, put the brake on and let the clutch out, if one axle is turning, that's the problem.
1999 Subaru Forester calipers
lmdew replied to tdbscoobydoo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, all configurations will bolt up with the bracket and matching rotor.
95 Impr. L - Need to fix rust spot behind left rear wheel (donor car years?)
lmdew replied to brycarp's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX93-99 will work. I have some cut out, but you will be able to fine them at the you pull and pay. Larry
yet another Speedo question
lmdew replied to a-marshal's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost likely the sensor since both the Speedo and Odometer went out. Look on the forward passenger side of the Trans, the sensor is over there.
Oil filter on tranny filter location
lmdew replied to Mdarius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMan, they have to work very hard to mess that up!
98 Outback Wagon Torque Bind... tires?
lmdew replied to lucasb's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry the fuse, if the FWD light does not come on, you have confirmed it's an electrical fault with the C-Duty. Many post on doing this with some great pictures.
EJ22 replace oil pan and leaky for twice times!?
lmdew replied to Suba_GL_87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMost likely you damaged the rear main seal. Most advise not to touch the stock seal as they almost never leak. Since you have changed the seal already, you need to confirm it's the source of the leak. If it is, remove it. Polish the crank shaft seal area with green and then gray scotchbright in a circular motion. Lube the new seal lip seal and carefully drive it into the block. Make sure the lip seal does not roll or get damaged.
1998 Foz gas tank issue
lmdew replied to Fozester's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSounds like a vent problem. Check the hoses going from the tank to the filler.
Impreza engine/main wiring harnesses
lmdew replied to ShawnW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI may have a harness for you. Give me a call. Larry
remove and replace ej22 engine in a 90 legacy to fix torque converter seal
lmdew replied to matts87glsedan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere are 4 bolts that go from the flex plate to the TC, you get to them through the access hole on the top right side of the block. A 6 point 12mm deep socket works well. Once it's disconnected, push the TC back, it will go back in about an 1/8". The Trans is heavy as can be! You can get it down with a floor jack but it's not the best. How many miles on the Car? If the mileage is high, the trans may be toast. Many threads on seating the TC, just use the search. You have to get the TC completely seated or you will damage the trans when you put it back in and start the car!
03 Baja Engine
lmdew replied to CzarMohab's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCheck http://www.car-part.com for engine but the offer you have above sounds good.
Building Keyless entry system for 95, 96 legacy
lmdew replied to FleaDog's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a few of the Subaru Brains and connectors. $45 shipped.
lmdew replied to Suba_GL_87's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXMake sure the pan flange is flat. You may have pulled the metal up around the bolt holes using the gasket. If so you will have to flaten them back out or get a new pan.
