153
Everything posted by lmdew
I've been very happy with the Grip Force Clutch kits off Ebay as well. I've put 6 or more in and they have been very good. Have the flywheel ground as well. About 50/50 on pulling the engine or Transmission. If you have any engine work to do, t belt, seals... pull the engine. Seal the Breather plate on the back of the block while you have access to it. I like the aluminum plates but those are getting harder to find. The Subaru Stampped steel kit with screws are about $20.
Work around the ABS ring, it does not come off without pulling the hub out. Make sure the E-brake cable is backed off then put the brakes together and adjust the shoes until they just touch the drum. There should be a little clearance. You can double check them once you have operated the brakes with the drums on by turning the adjuster through the back slot. Or, you could swap over to disk brakes. It takes the complete setup from a rear disk car along with the e-brake cables.
97 obs stalling
lmdew replied to davros's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I just had to replace a knock sensor wiring as it was cut on the engine I got from the yard. I just pulled the 2 wires out of an old harness I had and then re-pined them in the connector. Easy enough to do and then you do not have splices. I doubt a knock sensor would take out an ECU. I might have a used one if you need one. It runs in the open loop until it warms up. Once warm, the ECU wants to control the fuel, ign and timing. I'd take care of the knock sensor, clear the codes and then see what comes back. -
The racks are pretty rock solid. Make sure it's not the pump. I've had them side by side and I do believe they will swap. There is plenty of thread on the rod ends to adjust the toe. When you put it in, make sure you remove the little clamp on the lines and make sure you don' cross threat the hyd line fittings.
Right hand side of the Steering column. White Plug. I just put in a criuse system from a 98 OBS and it works great. Computer Brake and lower clutch switches vacumm unit under the hood Hose and fitting from the manifold Steering wheel control switch Cruise Switch. All the wiring is there, plug and Play
Just pull the TC and shaft and then drive the new seal in. You just have to make sure the TC is seated all the way when you put it back in. I always check to make sure if I push back on the TC it just hits the starter teeth and then I know it's fully seated. It will also pull forward about 1/8" when you bolt the TC up to the flex plate.
You want the timing mark on the crank gear rear tooth, it's a vertical line. Do NOT use the arrow on the front of the gear. You can often see the timing marks on the belt. It will have 3 lines across it, Cam, Crank, Cam marks. Otherwise the cams line up on the slot in the rear timing cover marks and the crank gear lines up with the dash mark on the oil pump cover. Larry Call if you want, I can explain it. 6 am to 8 pm MST 719-352-8468
