153
Everything posted by lmdew
I've been thinking about getting a 00-04 3.0 Outback to repalce my better halfs 98 Outback which had a 95 2.2 in it. I looked at one today and under the hood looks like a pain! No room anywhere. For those of you that have this Subaru, please let me know how you like it and what mpg you are getting. Right now I'm thinking I'll stay with the 98 2.2. Thanks Larry
I got my 98 Impreza back from the kids and the idle was high, 1250 or so. Everything looked good under the hood so I figure it was the IAC. 1/4 bottle into the 1" air hose, let it sit 20 minutes Start it up, had to floor it to clear the seafoam 1/4 bottle pulled in through the Vaccume port on the top of the TB Stop the engine, 1/4 bottle into the air hose again Let it sit 20 Minutes and repeat. Took it for a drive to blow everything out, idle 550-600 and smooth as can be. SeaFoam works!
P0302 & p0304
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
If the ALT hooked up and charging properly? I did a 98 once and had the same indications. I'd started it withoug the belt on the ALT and a low battery caused the faults. -
It's most likely the Oil separator plate that is leaking. Don't change the main seal unless it is truly bad as the new one may leak. Plan on spending 2 days as you will want to get the flywheel ground. If the engine is due for the Timing belt, pull the engine and do it all at once. It sounds like you can see the oil coming down the enegine, if so were is it coming from. If you do the T=belt, do the cam and crank seals and the oil pump oring and lock-tite the oil pump backing plate seals. Grip-force on Ebay has great clutch kits. I've purchased many from them and have always been happy. Larry
Most likely it's just cut right under the dash. The wire would be running out the drivers side firewall, in a large wire bundle about 1.5" in dia. It runs along the bottom of the top frame rail under the drivers side fender.. Pull the lower kick pannel and I'm sure you will find the wire cut under the dash.
Just wanted to confirm my thoughts before I order parts. I picked up a 99 OBS with the 2.2 motor. I believe this will have the new style TB Tensioner on it, but I will be able to change the tensioner and backing block to the old style tensioner and then use the 95-98 Timing belt Kit. Sound right? I'm out of town so I can not open it up to check. Thanks Larry
I drove the seal back down and the leak stopped. It's a pain, but if you take a 3/4" wrench and go over top the seal and up against the axle shaft you can push it back down. I'm going to check the local bearing shop to see if they stock the seal. I also checked a 2001 Forester and the rack has a rubber boot over the input shaft so the seal must be inside now.
