153
Everything posted by lmdew
1999 Legacy SUS
lmdew replied to coach9's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Tape will not pass emissions, they are smarter than that most of the time, as are most buyers. I always make sure the CEL comes on with the first turn of the key and then goes out after the car is started. Most emissions also plug into the OBDII which will show any fault codes. If codes are in the computer they will not pass emissions. Do it right or don't do it unless you are out in a area where there is no emissions check and you don't care if the CEL light is always on. -
It would be an neat setup. I had the only dodge carvan with a 3.0 6 cylinder 5 speed for a long time. The 6 caravan never came with a 5 speed but the dodge sedan did. It was pretty much a direct bolt in with a few welds for the trans support and shifter. I'm thinking the Subaru would be easy. I need a good CHEAP 3.0 with a bad transmission to check it out.
1999 Legacy SUS
Make sure the original engine and the replacement have the same EGR configuration, EGR or No EGR. Otherwise you will have the CEL on. -
1999 Legacy SUS
You can pull the covers and check all of the timing marks. If everything is lined up, you could do a compression check or better yet a leak down check. If you do the compression check on a cold engine by hand, you will not get full pressure, but if you had a bent valve it would show up. I like the 2.2 swaps as there are very few HG problems comparied to the 2.5 from 96-99 -
Rusty Brakes
lmdew replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Used calipers and a good flush should take care of the brakes. Have the rotors turned or take a wire brush to them in a grinder and clean off all the old rust. New pads and you will be good to go. -
If it's a 2.5 in an Outback, make sure the Head Gaskets have been taken care of. If it's the standard 2.2 Legacy it's a solid motor. If it's a 5sp, that's the best. If it's an auto, drive in tight turns and check for torque bind. Also watch to see if the AT Temp Light flashes 16 times after it's started. If it does, the transmission has problems. Clicking in tight turns, CV joints. Check the inner and outer boots of eht CV joints for tears. Temp gauge should be right at the 1/2 way mark. When was the timing belt done last? Great Cars, those Subarus!
