153
Everything posted by lmdew
They can be a pain. Sometimes I drop the exhaust, it makes a big difference. I center punch the nut and rod end and then once the rod end is off, I take a coat hangar and put it up to the nut. Then bend it 90 degrees over the end of the rod. Very easy then to get the nut back to the correct setting.
I don't know which one you have: Aluminum is best, IMHO as it expands as the same rate as the engine. Steel and Plastic are both going to move at slightly different rates to the engine block. All 3 are OK if they are pulled, cleaned and resealed with quality RTV and the screws put in will lock-tight.
Just put a 2x4 or some other block of wood under the trans pan at the front corner of the pan. It will jack right up without damaging the pan. The engine studs are great guide pins as you go together. The TC will rub against the starter gear if it's all the way seated and should pull forward about an 1/8 when you bolt it to the flex plate. It's easier to start all of the TC bolts from the bottom while the engine and trans are bolted together and still lifted up.
96 2.2 motors
lmdew replied to plodder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
A used engine is good if you need it. The problem with selling a used engine is you can't give a warrantee. Most of the Yards say 30 or 60 days. They self serve yards are getting 2-300 for an engine. If you put any money into it and try to sell it, you will be behind the curve. Cores or $100 each. -
I work on Subaru mostly because I like it. I fix a few and sell them. I tell the people if they have a question or problem to let me know and I'll take care of it. If you have done quality work, that should not be a problem. I had one fellow call me back 6-8 months after I sold him a 96 Impreza with 200K on it tell me it was using Oil. OK, the wife had driven that car for a year with no problems. I suggested he look for leaks and I doubted it was using the oil. I offered to take a look, but he never brought it back. I didn't hear from him for another 4 Months. Then he called me and told me the engine had thrown a rod. Now this was almost a year after I sold him a used car with 200K on it. I still offered to change the engine for $200 if he found a good used engine. I did that and he was once again happy with his Subaru. I lost some time, but I always try to ensure folks are happy with their Subarus.
Most lilkely NO. You have a wiring problem somewhere. You have to get out the diagrams, the motor is the Load, the Power is the Battery, but you want to find the Fuse that its coming from and then find the Ground. When you have the Load, Ground and Power you have the complete circuit. It's then a matter of checking that circuit. Go to www.brighterideas.com and look at the training on U-Tube. Dan has some great basic electrical troubleshooting tips.
Start with the easy stuff, battery and all ground connections clean and tight. With the wippers on, check for voltage at the connector, note you have to have the circuit loaded for a true reading. See www.brighterideas.com for the TesLite Tool that will allow you to do that. Otherwise leave the connector hooked up and back probe the connector with some fine metal strips. You most likely have a short somewhere. Time to get out the wiring diagrams.
