153
Everything posted by lmdew
strut ?
lmdew replied to Suba9792's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The extra height of the outback come from the bottom spring seat being about 1.5" higher. You should be fine. -
Passenger side of the transmission, you will see the linkage coming down. There a clip that holds the cable on to the transmission, remove it and then see if the cable moves. If the shifter is still locked up, its in the shifter/cable. If the cable is OK try shifting the transmission by hand, car OFF so you don't run yourself over.
I did a 98 2.5 to 2.2 swap. I sold the car, a few months later, the new Owner said they smelled fuel in the car. I always use the original 2.2 canister up front. I looked over all the fuel lines including the fuel pump and sending unit. I could not find any leaks. Anyone have an idea or had this problem before?
YOu can still clear coat, the sanding levels the paint and preps it for good adhesion of the clear.
The large fitting on the bottom goes to the Oil seperator on the back of the block and then oil drains down to the pan. The top fitting goes to the PVC valve on the intake. The 1/2" fitting coming off the middle goes to the Intake air box on the back of the intake manifold. Depending on the year and model, it goes to different locations. Look over the airbox and you will see the fitting.
First, don't drive it over filled, its bad for the trans. To get the pan to seal to the trans, both surfaces must be Clean, Clean, Clean. Then a nice even coat of RTV, I like the grey. bolt it up a little at a time in a cross pattern, and only to the proper torque. Then let it set for 24 hours to let the RTV cure. You should be all set. If its way over full, it may be leaking from the dipstick tube, where it goes into the trans.
VIN Check Please
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks, good info. -
VIN Check Please
Just trying to find out where the Forster has been. Thanks -
I've pulled many engine from the yard and only got one with a bad rod bearing, that one the filter was crushed. I rolled the dice on the engine thinking it may have happened at the yard. No such luck. Was the car in a crash, I like those the best as you can pretty much say they were running when it happened. Pull the injector connectors one at a time and see if the sound changes.
Strut mounts?
lmdew replied to 1-3-2-4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I always watch at the yard for a car that has newer KYB struts. $35 each its a steal. I trashed good rust free top hats a week ago.
