Everything posted by lmdew
97 obs stalling
lmdew replied to davros's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just had to replace a knock sensor wiring as it was cut on the engine I got from the yard. I just pulled the 2 wires out of an old harness I had and then re-pined them in the connector. Easy enough to do and then you do not have splices. I doubt a knock sensor would take out an ECU. I might have a used one if you need one. It runs in the open loop until it warms up. Once warm, the ECU wants to control the fuel, ign and timing. I'd take care of the knock sensor, clear the codes and then see what comes back.
Steering rack interchangability???
lmdew replied to LEATHER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXwww.car-part.com is a good source as well for used parts from yards if you can't find one locally.
Subaru long-term storage, and what Subaru of America told me
lmdew replied to AWDfreak's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPut stabil in but run it as empty as you can. The new gas will seperate and water will be in the bottom. Or Sell the car and get another when you get back!
lmdew replied to LEATHER's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe racks are pretty rock solid. Make sure it's not the pump. I've had them side by side and I do believe they will swap. There is plenty of thread on the rod ends to adjust the toe. When you put it in, make sure you remove the little clamp on the lines and make sure you don' cross threat the hyd line fittings.
92 Legacy ABS HCU leak help
lmdew replied to JETpilot76's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'll have to dig a little to see if that is the one. Larry
lmdew replied to JETpilot76's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI think I have one, if you can send a picture of yours. Larry Lmdew@hotmail.com
Cruise Control conversion on 97 OBS
lmdew replied to Suby Skier's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRight hand side of the Steering column. White Plug. I just put in a criuse system from a 98 OBS and it works great. Computer Brake and lower clutch switches vacumm unit under the hood Hose and fitting from the manifold Steering wheel control switch Cruise Switch. All the wiring is there, plug and Play
98 OBW running hot at idle
lmdew replied to MaddCelt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny air bubbles in the overflow bottle? HG leaks often don't show up until the engine is under load for a bit.
Tire rub, etc 2" lift 2002 OBW
lmdew replied to lesstutrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLower arms at the yard are like $20 and they come with all the busshings. Grab a good used one and bolt it up.
4eat front differential seal replacement
lmdew replied to crazyhorse001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust pull the TC and shaft and then drive the new seal in. You just have to make sure the TC is seated all the way when you put it back in. I always check to make sure if I push back on the TC it just hits the starter teeth and then I know it's fully seated. It will also pull forward about 1/8" when you bolt the TC up to the flex plate.
96 Subaru Impreza Outback 2.2
lmdew replied to Swidgett_Chick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou want the timing mark on the crank gear rear tooth, it's a vertical line. Do NOT use the arrow on the front of the gear. You can often see the timing marks on the belt. It will have 3 lines across it, Cam, Crank, Cam marks. Otherwise the cams line up on the slot in the rear timing cover marks and the crank gear lines up with the dash mark on the oil pump cover. Larry Call if you want, I can explain it. 6 am to 8 pm MST 719-352-8468
lmdew replied to Swidgett_Chick's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFill the oil so you don't trash the engine. It's not part of your not starting problem, which is timing most likely.
lmdew replied to lesstutrey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your control arm bushing are shot, I'd start there. A damaged control arm will cause problems.
Fan eating belt?
lmdew replied to Murthius's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Subaru Heat/AC Fans that I have seen are all direct drive. I have seen everything from leaves to mice in the Fan box. Drop the fan which is under the passenger side front counsel. Clean out the junk and inspet the fan. Year and Model would help.
Cruise Control for 91 Lego L
lmdew replied to Markus56's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes you will need the brake switch as well.
98 Legacy Outback Dual Moon Roofs ?
The interior sun shade will not slide back on the rear moon roof. The roof works and pulls the shade back but the it sticks on the way closed. Can I fix this without dropping the headliner? Thanks, Larry
How many different "gray" interiors for 95-99 Legacy?
lmdew replied to idosubaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA light and a Dark gray as far as I've seen. I'd call a dealer and ask the parts guys.
Duty C Solenoid.... stuck
lmdew replied to goms187's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe alignment pins can be come pretty corroded and make it hard. Make sure you have removed the speed sensor on the right side or you will damage it when you pull it out. If you search this form, there are some good posts with pictures.
Idle Air Control Valve Cleaning... Problem..
lmdew replied to J_S's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYou picture links go to google.mail?
Working on a 3.0 2000-04
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the info.
I've been thinking about getting a 00-04 3.0 Outback to repalce my better halfs 98 Outback which had a 95 2.2 in it. I looked at one today and under the hood looks like a pain! No room anywhere. For those of you that have this Subaru, please let me know how you like it and what mpg you are getting. Right now I'm thinking I'll stay with the 98 2.2. Thanks Larry
99 OBW just completed EJ22 swap. Love it!
lmdew replied to wavekayaker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI love these swaps, but good 95 2.2 are becoming harder to find. You guys need to stop this so I don't run out of engines.
98 Impreza High Idle Fixed, SeaFoam
lmdew replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHigh idle came back today so I went in for the deep clean. Q-Tip and lots of cleaner. I can't fault Seafoan the car has 297K on it.
I got my 98 Impreza back from the kids and the idle was high, 1250 or so. Everything looked good under the hood so I figure it was the IAC. 1/4 bottle into the 1" air hose, let it sit 20 minutes Start it up, had to floor it to clear the seafoam 1/4 bottle pulled in through the Vaccume port on the top of the TB Stop the engine, 1/4 bottle into the air hose again Let it sit 20 Minutes and repeat. Took it for a drive to blow everything out, idle 550-600 and smooth as can be. SeaFoam works!
Thinking of painting my car, opinions please
lmdew replied to newsoobdude's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThere is a lime green 97 in the yard by me. You can't miss it.
