153
Everything posted by lmdew
In the wagon it's just behind the rear seat. In the Sedan's it's under the rear seat. You'll see an oval panel with 4 screws in it. Pull the panel and you will see another oval panel with many 8mm nuts and the fuel hoses and electrical connector. Spray the fuel hoses with WD-40 or some other lube. Carefully remove the hoses, electrical connector and then the 8mm nuts. Pull the panel and pump. Get a Subaru pump. Even a used one is better than aftermarket.
www.car-part.com Get the exhaust from a rust free state.
- 8 replies
- exhaust
- catalytic converter
(and 3 more)
Tagged with:
Pull a used Subaru Halfshaft from the yard. Clean, grease and reboot if needed. Heck, just to see if the symptoms go away, install as is. Rebuild down the road if necessary. I take my 3/4" 4' long snapon ratchet with 6 point socket to the yard. No nut has ever beaten that tool. If the outter spline does not move freely once the nut is off move on to another Subaru. Make sure when you put it in the innner rollpin is propperly aligned. If it's 180 out, you can start it but it will jam before you get it all the way in and you will be hard to get it back out!
I've been working with atp's SpotLight solution for 20+ years in commercial aviaiton. https://www.atp.com/spotlight/ When teaching SpotLight to Mechanics I tell them Troubleshooting is Troubleshooting, aircraft, car, boat, motorcycle. It has to be a process. SpotLight is a knowledge base which captures and keeps tribal knowledge forever, making it easy to find the Solution. Same thing the USMB does but larger and easier to use. USMB works for us. I've searched for solutions and I've found them. One was even submitted by Lmdew years earlier I had forgotten the details but the USMB did not. Larry
|P1101 SUBARU code description Neutral Position Switch Circuit High Input (A/T) Neutral Position Switch Circuit Malfunction (M/T) Yes it could be causing your idle issues. I've done a few Auto Manual Swaps and the ECU needs to have a good signal. You said this all started after the filter change. Did you do anything else? How long was it running well?
I've removed the inner CV Joint, to reboot an outter that would not come out. A pain to try to clean out the old grease out of the outter, but you can do the best you can and then add new grease and a new boot to the outter. The inner can be completely cleaned and regreased and a new boot installed and then put it back on the trans. Got to do what you got to do sometimes.
I've had them rust so tight I had to change the knuckle. Put a large drift on the end of the shaft. Keep the nut loose but on to protect the treads. After soaking in PB Blaster of some other oil give it a good one. Pin punch to mark the top alignment bolt. Then remove it and loosen the bottom bolt. It will allow you to tilt the knuckel enought to remove the inner CV. You can then get the otter joint out of the hub.
CV Noise
lmdew replied to sunraker's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Going back to a Subaru Part was a good choice. Replacing the same part numerous times is not. -
They do have the testers to see if there is combustion gas in the coolant. It's not 100% but another indication. Sometime HG only leak under heavy load when hot. Watch the temp gauge. Subaru's most often sit just below half way. They come up to temp pretty quick and then stay there. Same position all the time. If the temp gauge is going above normal you have a problem.
