153
Everything posted by lmdew
I picked up a 98 Impreza and the shift bushings were gone on the aft attach point. I went to the Subaru Dealer, they did not have the $18 each bushings in stock, but did have the complete u-joint for $65. This car had the step bolt with bushings not the seperate steel bushing with a straight bolt and plastic bushings. I got it but then I stopped at Ace Hardware on the way home. I picked up: 2) bronze bushings with a top lip ID 3/8", OD 1/2", 1" long 1) Step Bolt 3/8" x 2" long and a lock nut Steps to replace the worn componets. Jack and support the car on jack stands Remove the exhaust heat sheild attached to the transmission rear support Remove the rear trans support, this gives you more access to work Remove the 12mm nut from the lower shift linkage support arm Remove the 12mm nut and bolt from the shift linkage arm You know know if you have the stepped bolt linkage or the one with the additional steel bushing. If you want to, you can remove the u-joint by driving out the two roll pins at the front of the u-joint, I did but the shift u-joint to trans input shaft was so rusted (not a CO Car that's for sure) I could not get it off. Using a pipe cutter, cut one of the bronze shift linkage bushings down to 1/2 Long and debur Remove any of the old Plastic bushings and then insert the new bushings Attach the linkage using the new 3/8 stepped bolt and lock nut. I also put locktite on the nut as there was only about 1/4 of threads showing. Put it all back together. I'm sure this will be a life time fix for way less than the Subaru Plastic bushings. It shifts great.
I have a 99 2.5 SOHC from a forster with 140K on it. $400 + shipping from CO and its yours. I've done lots of swaps 96-98 Outbacks using the 2.2 from a 95 it swaps right in. On the Trans Starter stud missing, you can put in a heli coil in the trans hole and then bolt the starter up. Do this while the engine is out. How many plugs are on your engine to firewall harness? Two?
Do the adjustment at the brakes first. If you still need to adjust the cable, you can do it at the brake lever. If you still need to replace the cable it is easy, a clamp under the brake lever, a couple of more on the way to the brakes and then R&R at the brake backing plate. I doubt you need a new cable, unless its rusted tight.
You can also put a 1/2" breaker bar on the socket and rest the handle down right in fron of the battery on top of the frame rail. Make sure it's firm against the rail and the socket is on well. Hit the starter for a second or two, and the bolt will break free. Note: You can have nasty things happen if the breaker bar is on the wrong side of the car.
Jack one side of the car both front and back wheels off the ground. Put a mark/tape at 12 oclock and a mark on the fenders. Then rotate the tires 10 revs, they should both still line up with the marks. If they are slightly off, go to the other tire and rotate them again after line up the marks. Some slight slip in the viscous coupler can account for this slight change. If you have two different ratios, the marks will be way off. You could also pull the rear section of the drive shaft and see if the wine goes away.
It would help to know what Subie you have. A simple check for low freon is to put the AC on and then pull the pressure switch plug off the dryer and jump the pins. If the clutch kicks in, you are low on pressure. DO NOT Run it for more than a few seconds this way. Look for traces of oil around the fittings and on the front of the radiator to check for leaks.
I was looking for a gas leak due to gas smell in the car the other day and I remove the panels under the cargo floor of the wagon. Both side Sending/Pump Covers were as rusted as can be. There was no leak, but I did the Krol/PB Blaster Treatment. I hope I never have to pull them, I doubt the nuts will come off without the studs breaking. This was a MI car. If I was in the Rust Belt, I'd pull the covers and clean and treat them.
I've never seen a rear dif with a front seal leak. It's leaking where the drive shaft bolts up. I have pulled the splined front adapter out of other rear diffs but I don't remember if the seal was easy to get at or not. Anyone know how to change out the seal? I think I can do it with the rear dif in the car and just drop the drive shaft. Thanks
Tie Rods Outer
lmdew replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No difference that I have noticed. The 2000 and newer have a larger jam nut but I still think the rod dia is the same.
