lmdew
    153
Everything posted by lmdew
  1. Yes, folks have had problems with the aftermarket half shafts. Lots of folks say Subaru only or the half shafts off of www.ccrengines.com web site.
  2. There is a little metal spring clip that the cable is held by. If you see the c-clip on the cable, it goes against the spring clip. Its black steel about 3/4" long and rounded to fit the cable with a little tab on it to use to open it up. No need to remove anything, just look up there and you should see it.
  3. I've got a set of rotors, calipers and brackets with pads. 30K miles on them. $200 shipped to a business address. Larry
  4. It's part of the starter. 14 mm bolt on the top, 17mm nut on the bottom, 12 mm nut on the positive battery lead and the connector on the back. Hit the local yard and get a used one.
  5. Start with the simple stuff, clean and tight battery terminals. Sounds like the starter soleniod is hanging up. Most Auto parts places will check your charging system for free.
  6. Drop in a 95 2.2 and be done with it! I do this all the time, as it's cheaper, I feel I have a better product and there is not that much difference in HP. I've seen may 2.5 that had the HG done only to throw a rod a year or so down the road.
  7. I'd just go back to the OEM coil Pack. I don't believe a coil pack will fail when the engine is cold but be OK when its warm. The non-oem one could cause other problems though. I bet your OEM coil pack is good if the symptoms did not change when you changed the coil.
  8. Make sure all the electrical and hose connections are good. Electrical Clean and tight.... Was the CAT code there before the HG? Double check every connection.
  9. Put an OEM coil back on the car. Change the coolant Temp Sensor. Make sure the battery and ground connections are clean and tight.
  10. Unless they are very rusted or have sagged so it's noticeable I don't think you're getting much out of new springs.
  11. Make sure you don't push the pedal all the way to the floor. Put a 2x4 under the pedal so the master cylinder pistons do not move into areas they have been in years. If you want, run down and you can grab my pressure bleeder and use it. Works great and no pumping. Larry
  12. Coolant temp sensor, if it's running rich all the time. How did the plugs look? If you have a good multi meter you can back probe the O2 sensor harness and record the voltage. If my memory serves me correct 0.5 to 5.0 volts is the range. The higher the voltage the richer its running.
  13. Larry Dew
    1057 Dancing Horse Drive
    Colorado Springs, CO 80919
    my PayPal is my email - Lmdew@hotmail.com
    Thanks, Larry
  14. The lights and brakes are most likely not related. Check the fuses for the lights. The Brakes should be inspected, checking closly for proper clearance of the ABS Sensor and tone ring.
  15. The rear Extension housing is pretty easy, search torque bind on the USMB there are some very good posts with pictures of the job. About 4 hours if all goes well.
  16. You need to trace the wires for each circuit. Load Power Ground When you find all three you have a complete circuit.
  17. Does it do it when it's up on jacks as well? Can you push the piston back into the caliper, take a screw driver and get it between the pad steel lip and the caliper bracket. It should push back in with steady pressure. If it's blocked, I'd crack the line up at the top of the wheel well and see if it goes easy now. If it does, the flex line is the problem. Otherwise work you way back to the MC. Lot's of brake bleeding will be needed if you open the system this way.
  18. Go under the hood and check the battery terminals. If they are loose or have corrosion all over them, clean them. Follow the red wire back to the starter, make sure the terminal is tight there. Give the starter a good wack with a rubber mallet or wood handle. Some times the contacts stick. Have someone try to start it and listen for the starter to click. If you have a meter, you can check voltage at the battery and then the starter. If there is no voltage getting to the starter nothing will happen.
  19. Brakes will swap over with some work on the rears. Inter front seats will bolt in the backs are larger You'll want to pull the ECU and all the wiring, this will not be plug and play. Front Struts should bolt up, you may need to change the top mounts over. The exhaust will have to be modified to fit the Impreza.
  20. It may be the wheel bearings making the noise too. Jack the car and grab the top and bottom of the wheel an try to move it back and forth and side to side. Any movement is bad. Also spin the wheel, if it feels rough the bearing is most likely gone. Yes, always change brakes in pairs.
  21. When the TC is fully seated in the trans, it will sit back about an 1/8" from the flex plate when the trans and engine are bolted together. You can than use the flex plate bolts to pull the TC to the flex plate.
  22. That was Easy, water in the connector from the firewall to the engine. I always steam clean the engines and engine bays, I guess with the winter weather it did not dry out enough. I'll post the Checks for the Knock Sensor when I get time.
  23. If you can run this VIN and send me the report that would be great! Jf1sg69675g704991 Lmdew@hotmail.com Thanks, Larry
